Hi, could someone please recommend where I can buy round files 0.4, 0.5, 0.6, 0.7 and 0.8 mm? I need high quality files to tool out some grooves for stropping the rigging blocks made of wood.
They only send to a Austria adress …….for such small diameters I use reamer
@Jimsky we had this thema some weeks ago - you mentioned somewhere the correct term for these small tools
They are used for carbuartors
View attachment 439517 View attachment 439518
View attachment 439519 View attachment 439520
The smallest is 0,33mm I found after a fast research
Stahlwille Düsenreibahlen
Stahlwille Düsenreibahlen online kaufen bei Contorion: ✓ Versandkostenfrei ab 150 € ✓ 30 Tage Rückgaberechtwww.contorion.at
I cannot use this as it produces a square slot. I need a round slot.why not use jewlers jig saw blades also used for guitar pearl inlay?
Unfortunately these are a square profile tools. They are used to enlarge the round holes by inserting them into a hole, rotating and pushing them in. They are not designed for filing. Ones I checked did not even have an abrasive surface - just the bare steel.for such small diameters I use reamer
These are square and bare steel. I checked with the retailer.A google search for modelcraft PBR2193 looks promising
yes a bare steel - and a square cross section - I am using them by turning in small holes and the edge is scrapping the hole.Unfortunately these are a square profile tools. They are used to enlarge the round holes by inserting them into a hole, rotating and pushing them in. They are not designed for filing. Ones I checked did not even have an abrasive surface - just the bare steel.
This is exactly what I need. Thanks. Unfortunately they do not ship to Canada.Look here:
Post in thread 'La Créole 1827 by archjofo - Scale 1/48 - French corvette' https://shipsofscale.com/sosforums/...o-scale-1-48-french-corvette.7643/post-325825
There is a discussion about these small files.
