- Mar 22, 2024
double post...
ok - mine would be great to widen the holeHi, Uwek, I need a file to do a round slot on rigging block as on this picture.
gesswein.ca
I want it all, I want it nowFollowing up from an earlier post: dental files are not what we want for our hobby.
Thanks for a tip. How do you finish, polish your block when you completed it?You can positioning the place in that way where you want to make the slot on a easy way to help you when going on with the file or like I do with a cutter.
I always use theseThanks for a tip. How do you finish, polish your block when you completed it?
Thanks. I read too many negative customers reviews these. They say these files do not grind off much material as they are just scored stainless steel wires. Do you find them useful?This is a set of very narrow files that is designed to make string slots in a guitar's top nut.
I have scarcely used them for modelling and like I remarked, mine are not the real thing. I do however suspect that most of those reviews are based on cheap specimens. A professional luthier would use this tool to shape the natural bone nut of an instrument worth thousands of dollars. By the way, a cheap set like the one above can be had for less than 5 euros.Thanks. I read too many negative customers reviews these. They say these files do not grind off much material as they are just scored stainless steel wires. Do you find them useful?
Technically that is called a 'broach;. A reamer properly is often tapered like a broach but is round in section and has flutes with cutting edges. A broach scrapes a reamer cuts )a very little at a time).bare steel - and a square cross section
Those are also used to clean the tips on oxy-acetylene torches so they are available at welding shops.This is a set of very narrow files that is designed to make string slots in a guitar's top nut. This specific set - my set - is not of very high quality, but those that are used by professional luthiers of course are.
A set like this can also be bought at a welding supply shop or online “orifice cleaning tool”This is a set of very narrow files that is designed to make string slots in a guitar's top nut. This specific set - my set - is not of very high quality, but those that are used by professional luthiers of course are.
