Hi Michael! I was expecting you to ask if I made these with sandpaper ROTF...
Yes, I do believe carving/shaping is much more satisfying using hardwoods. I sometimes see posts on build logs that say something like, "it's all fuzzy but you can't see it in real life." And even if that is true (hmm...), I would struggle working with soft stock. Given the amount of time invested I would advocate for using the best materials you can afford.
BTW: true boxwood (European boxwood) is really no longer available (or so I have been told). You will see it on various build reports but that is old stock coming from someone's stash of dried timber. What we have available today is a genetic relative but is quite a bit softer than the real thing. I am using Castello boxwood which is just a bit harder than pearwood - but about 40% softer than the real thing (but still 50% harder than cherry - and almost 3x harder than the limewood most kits provide).
Anyway, different species of woods have their proper place in our hobby - but the tighter the grain and the harder the wood the easier it is to carve and shape (oh, and the magic happens when you have a blue background ROTFROTFROTF).
I’m getting a blue background today….need some magical assistance….
Good afternoon Paul. Wow! You have “outdone yourself “ yet again. Reading through the chats, I’m sure the correct tools and using the beautiful boxwood makes for good work however, to produce this level of detail and accuracy one needs skills…. You have plenty.
Cheers Grant
Very good work on the bitts - I recognized once more, that I nee also such a blue background -> very good photos of these details
Having a past as professional photographer (days of film, chemicals and paper) a background can be as simple as hanging an ironed bed sheet from bookcase or curtain rods to act as background, blocking the images behind it.
Your progress is always a feast for the eyes, Paul you do an excellent job and everything looks so perfect.
Thanks Tobias. Maybe not so perfect (that would require a more proficient use of a mill than I am capable of right now) - but I do enjoy the challenge of working with my hands to create things that have a measure of precision. When this build is done I may try my hand at carved decorations - perhaps a stern section? Well, I'll change my mind a dozen times before that happens ROTF.
Hello Friends,
Thanks for all the likes on my recent progress report. You are a fine bunch!
I began my weekend finishing up the riding bitts:
And now sitting loosely in place on the ship:
Another structure that sits in relationship to the upper and lower deck beams (actually between in this case) is the top half of the well. This is a fiddly louvered affair that required some serious adaptation of the kit-supplied parts as they were incorrectly (incompletely) milled:
But after several false starts I managed to come up with something usable:
I'm leaving the port side open to allow some sight lines into the well...
Here is the upper well sitting loose on the lower deck:
I still need to add door hardware but that can wait for now.
You are kind to take the time to step away from your own builds to see what I have been up to!
well...nothing new, dah! As I just said - what else is new :p As always... the precision and accurate modeling! Forget about the kit's supplied parts, you can make your own! If you are doing scale models with such accuracy, I wish I could be your orthodontic patient...perhaps now it is too late...I cannot find my teeth anymore ROTFROTFROTF
Hello Friends,
They woodwork looks so NEAT! What type of wood is that? It has such a fine grain.
Hello Friends,
Good morning Paul. I have no idea how you model such beautiful parts, joins etc etc….so I will just sit back and appreciate your work. Cheers Grant
