1880s Nile Steamboat 1:32 scale
Toronto Canada
I have so much materials left over from previous kits that I decided to scratch-build a model of an 1880 era Nile side-wheeler steamboat. I was impressed with the one in the epic film Khartoum (1966, Charleton Heston, Lawrence Olivier). In the film this is the steamboat which brings General Gordon (Heston) in 1883 to Khartoum to try and rescue the inhabitants from an insurrection. This boat is later outfitted with guns and makes an attempt to run an escape down the Nile under the guns of the rebels (which was unsuccessful).
There is not too much to go on. I could only take screen shots from the film and there are a few examples from the era of of similar boats. So, I will be building my own version, more or less similar to the one in the film, but at a smaller size.
Stay tuned!
Stay tuned!
good luck
I will keep following with great curiosity
I started out by gluing 2 pine (1" x 6") boards together. In an ideal world I would be making some sort of a plank-on-frame model, but I just don't have any proper tools to create the frames, etc. However, since this is a flat-bottom boat I decided that I could sand and file the solid wood it into a more realistic shape. After gluing, I aded some shims at the front end to create a somewhat upward-inclining deck surface. I then added planks, but not the entire surface since I will be adding some deck cabins, and am trying to preserve my limited supply of planks (I'm trying to build this with a minimum of material purchasing. We shall see if i can get away with this!). I will be adding some planks on the hull to hide the shims and also to cover some gouges, etc.. But I will probably ust plank to the waterline, unless this looks too weird.
I also planned to work off some detailed plans that I would create complete with measurements, etc.. On a previous project my measurements were slightly off and in the end I chucked the plans and ended up designing on the fly, holding up pieces of cardboard templates and figuring out my next move.
The next stage with be shaping the hull, champfering, adding curves and narrowing towards the stern.
Thanks Peter. I'm trying to replicate as much as I can, although my boat will be a more compact version of the original. I like working at a larger scale, like 1:32 or so (all of my trams are 1:24 and my locomotives are 1:32). I have made progress to make the side wheel housings and the paddlewheels. I also used an X-acto to cut out the curved portions. It is not perfect, but I just have the knife and sanding. So it'll have to make do!! At this point I can't decide if there will be 2 levels of cabins or only one.
Those parts are looking very promising with nice details, Carl. With a nice color combinatie.
I put together the various components of the paddle wheel housings. The next part will be figuring out the various cabins on the main deck.Still need to do a bit of fine sanding. I hadn't realized how rough the surfaces look when photographed close-up. I also now realize that I should have built the decorative framing and window frames with 45 degree corners. It looks so clunky with everything just butting up. Of course I was so excited to add the framing that in my excitement, I didn't think this through. I will do proper framing for the rest of the build.
Your stuff is terrific. I'm so pleased to see your work. More paddle-wheelers like you are needed in the hobby!
Thanks. I do like paddlewheelers. Although I admire the sailing ship models, my shaky hands couldn't manage the rigging! I also got intrigued by paddle wheelers when in he early 80s I happened to travel on a steam-powered side wheeler boat. It was the Waverley, the last still running (at the time) ocean-going, passeneger carrying, paddle wheeler. I was mesmerized by the steam machinery, etc..
How are you doing? What are you working on??
I made a little more progress on the Nile steamer. I more or less finished the paddle wheel housings, and built a few staircases. Using some 3/32" sheet wood, I started to work on the aft main cabin walls. This time I started to make 45° angles for the window frames, etc., The plank-cutter shears I bought a few years ago finally paid off!
A bit more work on the Nile Steamer. I decided to curve the back wall of the aft cabin to make it conform (more or less) to the roundish shape of the hull. So I made a form from a chunk of balsa wood to hold the shape of the pieces forming the rear wall. I also added a few shutters for some of the windows. In the very hot climate this boat would have had these type of shutters - slats that open and close - as opposed to glass windows. I installed the walls and painted. But it's evident from the photos that I still need to smooth out some of the wood (How come you get to see all the imperfections when viewed on a photo, but my own eyes doesn't seem to see them?!). I also painted and glued the steps onto the paddle wheel housings. Nest will be the forward cabin.
I have a question maybe someone can help with. On most of the Nile steamboats there are what seem to be portholes on the hull just under the main deck areas. I know (?) that there is no lower deck on these flat-bottomed boats, so are these just open holes for ventilation? I have Googled all over the place for better images, but all I can make out is that they are just openings. What could they be and what purpose do they serve? Any ideas?
Hi Carl,
It seems that they come in all shapes, in some there is certainly deck space of some sort down there, in others the hole looks like it is low in the bulwarks, perhaps for mooring? I have seen some pics showing portholes over these openings, also have seen them used as a sort of fairlead with a mooring rope running through. Her is a pic of one with sort of both. Hope this is a bit of help. Your doing a great job, looking forward to your continued good work. Jack.
