- Oct 1, 2023
I just noticed that the notches in 126-56 are not centered. They are off enough that the slot would be visible if I try to average them out
What did you guys do with this? I don't remember any thing about this in the build logs
Puzzled,
TedView attachment 450041View attachment 450042I'm
So you're looking at six parts in total, just to make sure.Part 56 is used in three locations; both mast feet and the wheelhouse, so you should have three dwn and opposite parts.
I found five and will remake the otherSo you're looking at six parts in total, just to make sure.
Ted, I used aftermarket deck planking in leu of the fabricated deck plywood pieces so I would not be much help here other than to say FOLLOW the plans exactly, step by step and always read ahead at least 2 steps.Would it be better to use the finish deck parts to do that checking instead of a planking strake?
Thank you DanielTed, I used aftermarket deck planking in leu of the fabricated deck plywood pieces so I would not be much help here other than to say FOLLOW the plans exactly, step by step and always read ahead at least 2 steps.
Again, I am not qualified to answer your question however I would think the deck openings lining up with the various frame openings and deck penetrations would take precedence. You would need to have all your deck beams and carlings installed to know this though.I'm thinking that the finished deck part goes back tight to where part 103 sits over part 102. Is this correct?
Hopefully,
Ted
Plus a quick conversation with the drawings could be very enlightening…Again, I am not qualified to answer your question however I would think the deck openings lining up with the various frame openings and deck penetrations would take precedence. You would need to have all your deck beams and carlings installed to know this though.
