Thank you kindly, Peter. It's just a matter of patience...
Thank you, my friend. It's really fun sharing my work with all of the kind members of our forum. Maybe someone will pick up an idea or two???Details, details, details......I am always impressed with all the details you add to your model. It is also great all the documentation you do with build. This is truly a great source for future modelers. Great job Doc.
You are very kind Roger! My thanks!Wonderful work Paul, the detail is stunning. I just love those lanterns.
.Thanks so much, PaulThanks, once again, for all the likes on my previous posting!
On the Kingfisher there are posts that support the centerline of the beams of the lower deck as well as the beams of the upper deck. The posts for the lower deck are a simple affair which would have been quite suitable for the hold:
But I wanted to make something more 'elegant' for the upper deck beams. A few years ago I had purchased a mini-lathe which I never used. Would it work to turn posts from square stock? Let's find out...
First, some blanks with layout lines:
A back-cut to prevent any tear-out:
And a preliminary beveling of the sacrificial end that would go in the chuck as well as the center turned portion:
I purchased this mini-lathe for around $30 USD:
Here we go!
Just for fun I recorded the turning of one of the posts. As you will see I just used needle files. I guess someone who knows how to properly use a lathe would use a carbide cutting tip and a pattern jig but that's above my pay grade. The video is about 10 minutes long and will show the steps I went through to make a single post. I suggest you 'fast-forward' as it's not exactly a big budget action-adventure film:
Here is a photo of the finished product:
And now the total run.
Of course, no two are exactly the same, but I believe these will work! Add another 'skill' to my model-building repertoire.
They are looking very nice, Paul. 14x10 min.? Or your skills approved during the milling?Thanks, once again, for all the likes on my previous posting!
Here we go!
Like the quote from Pippi Långstrump from Astrid Lindgren: “I never did it, so I think I can do it”.Add another 'skill' to my model-building repertoire![]()
Good morning Paul. You have just blown away my excuses for “crappy” lathe work being :a cheap lathe and needle files. Thanks much appreciatedThanks, once again, for all the likes on my previous posting!
Here we go!
. Cheers GrantThank you Stephan. I also tried to make a scraper to add the raised round areas but that was a total fail...For such small parts, needle files work the best. More accurate. Good job.
You are most welcome. I was actually thinking of you when I decided to record my solution.Thanks for doing and posting the video. It is magnificent and very instructive. I actually slowed it down to half speed to enjoy every minute twice and detect the subtle maneuvers of a master craftsman at work.
Thanks Paul.
Yup. That thing won't turn a table leg - but it sits on a table top very comfortably. It makes a few noises and I felt like it was going to die any minute but 'job done.' If I need to replace it I won't go broke doing so...Thanks so much, Paul
I have a similar small lathe and play with it often. Not over-powered but great for such small work.
Your skill and steady hands is an inspiration.
I LOVE that quote Peter! It rather efficiently sums up my approach to this new hobby!They are looking very nice, Paul. 14x10 min.? Or your skills approved during the milling?
I am sure you do now more then you thought you could do a few years ago.
Good morning Paul. You have just blown away my excuses for “crappy” lathe work being :a cheap lathe and needle files. Thanks much appreciated. Cheers Grant
I hope I don't accidently catch the CNC milling machine and 3D printer I use in the background of a picture; or the work table of the master modeler I hired from Russia...Little by little Paul is starting to share his hidden toolset.
Again beautiful work.![]()
Agreed. And I rather prefer working with my hands anyways...The posts turned out great. Amazing what you can do with some simple tools.
Thanks Daniel. I was surprised as wellWhat a great turnout with your lath Paul!
Thank you for this nice post, Nigel.Playing catch up on a large scale Paul. OUTSTANDING work!
The speed at which you gain new skills amazes me and I can't comprehend what you will be building in ten years.
I am not a fan of Holly for decking but your model has made me take a 180 , with the other colours, it looks so right on this build.
Kind Regards
Nigel
interesting use of a needle file. I never thought of using it that way. Seems to work well.Thanks, once again, for all the likes on my previous posting!
Here we go!
