I'm having a tough time following your thread so I wondered if I was going in the right direction or not.
Exactly, and the point is that in the old restoration reports there is mentioning of the fact that the keel was drilled on several locations, apparently to add weight or a false keel to stay upright in the water.
Oh, before I forget: calculating the length of a warship on the basis of the distance between the gunports is very well described in Leendert van Zwijndregt's book of 1755. You can find it in the translation of my book 'In Tekening Gebracht'I sent you some time ago.
No, I don't have the slightest interest in being referred to. However, if you insist, I will also add the reference to your work if necessary. It won't be much trouble.
to stretch thee date of production of the drawing a bit.
The term "Frigate" was often used to mean many things into the early 1700s. It often meant a ship that was less than a Ship-of-the Line..
Thanks for your comment, Ab, but how does this relate to the real essence of the issue? Anyway, I am going to stick with the term ‘heavy frigate’ as it best reflects the nature of the vessel, especially in universal terms, that is, against other fleets. I don't mind that for someone else it will also be ‘a low charter man-of-war’.
Highly unlikely it could go much beyond 1700 – square tuck stern, double wales, overall design simplicity without using even the corrective diagonals, let alone design diagonals. It would be already too much old-fashioned for the middle of the 18th cent.
there is a drawing by Leendert van Zwijndregt from 1757 showing double wales (sorry for the bad picture, my copying machine has its limitations):
Clearly double wales.
About the dating: all well, but the reasons Waldemar gives why the drawing has to be dated as early as 1700 do not seem very solid to me: square tuck sterns and double wales were still in use in all admiralties until after the first quarter of the 18th century.
Here a drawing by Gerbrand Slecht, active on the Amsterdam admiralty yard from 1723-26:
to the best of my knowledge Dutch frigates never had more guns than 40.
