What to say ..? I used:So are you going to show how you constructed this device? I would be very interested in building one myself.
Very helpful. ThanksWhat to say ..? I used:
- Plywood thickness 15 mm and 6 mm that I had in the "shipyard"...
- 1 standard cutter blade
- 1 bolt diameter M8 x 60mm + 2 washers + 1 nut
- 2 4mm self-tapping screws
- 1 piece of measuring tape of the ones that are given away in supermarkets
In short, a jic put together without pretensions using the first things that came into my hands.
I'll probably make a better one... in particular:
- I would make the right side longer, let's say around 200 mm
- I will replace the cross-head screws with screws with knobs
- I will make the angular striker with a circle-shaped milling for locking
- ... and other small improvements.
I hope I have been helpful.
HI
Wow, that strips cutter looks absolutely brilliant! What an incredibly clever and precise tool perfect for making model shipbuilding so much easier and more professionalWhat to say ..? I used:
HI
