- Oct 1, 2023
I have been using the hull planks and the part 31/32 aligned with the waterways to come out with the elevation I used. That's why it was installed so low. So that the top of the transom met with the top of part 32.Hi Ted. In addition to Henk's post:
I see in your last post that you have already took off the transom part.
The part must be in place much higher.
It's documented on page 19:
The inner part (see picture 114 + 115) and outer planks (see picture 117 + 118) must be at the same height as the 'spider legs'. Everything was flattened horizontally so that the lower part of the railing would later lie flat on it.
And you have to realize that on the planked side the hull planks have to fit to that rear part.
See this picture from the manual, pag 23:
The common option for that planking is that the end of the planks fit over the transom part.
I think that you have to take more time to study the plans and manual.
So, always look a few steps ahead in the manual. That you fully understand 'the why' of what you are doing.
What helped me was taking some hull planks and lay them over the frames and look for the flow of them over the frame to that transom part. From the top where the railing will come to the bottom where the transom parts meets the keel.
That’s looking better, Ted.By
Thank youz
TedView attachment 455310
That's what I have been doing. The scuppers line up great. The top of the transom lines up great ant the plank 32 fits the profile of the frames.That’s looking better, Ted.
Another check: that the scuppers are aligned just above the waterways.
Thank you Daniel.In your booklet see page 19 picture #117& 118. On your redo move the transom down until the two yellow lines match. If it ends up being too low, you can always add a plank on top.
This is another of the many tough to get right areas of this ship. Good luck.
I just now see where Peter has already covered this.
