usually... but not in this caseusually you would need also the longitudinal lines
starting from this drawing... is it possible to trace the geometric position frames along the keel?
Hi Davethey should not be the same distance apart. as the curves of the hull change the closer together the station lines become. Midship where there is little change in the shape of the hull so the station lines will be farther apart.
Dave, I agree with you that if the model builder is only making frames based on the stations shown on the plan rather than fully framed, they need to be attentive to their location on the keel. but I do not think the station lines are closer together, it is just that only every other station line is shown in the center area of the profile drawing. Same thing happens on the body plan. In the plan below on the left I sketched in stations 24 and 26 and marked 22, 24, and 26 on the profile view on the right in magenta. I can't tell from the pictures you posted but I venture to guess it is the same thing, they merely show every other station for most of the hull length. In the below the distance from station to station is always the same, 26 inches. but when the plan only shows every other station the distance is 52 inches. I think you can see in the drawing the original station numbers and not all of them are drawn in by the draftsman.here is an admiralty drawing that shows the station lines are closer together at the bow and stern
The answer is included in the posts by the others (I guess)All very interesting, but no one has answered the initial question that gave rise to this thread
This is the drawing I'm working on.. The CAD gives me these distances between the frames:
36.4 34.4 35.9 35.9 70.3 69.3 67.3 66.8 65.3 66.3 31.9 33.4 31.4 33.4
At this point I can correct the values and make them consistent with each other.
