- Oct 1, 2023
Thank you Daniel. I'm looking it up right now.Hello Ted, to see what I used look at my post #385, #387, and #457.
Ted
I used what's been referred to as "liquid wood", but after curing, the stuff is tougher than the pear wood of the planking, which is not good. The pro is that it doesn't show any cracks after being exposed to different temperatures and levels of humidity.What is a good sandable primer to use on the bare wood.
Thank you all,
Ted
Congratulations with this milestone, Ted. Now she starts showing here nice lines.I got busy with my Dremel and set the little lady free.
A major milestone in my mind.
She sure looks a lot smaller.View attachment 457667
Congratulations on setting her free. She is looking very nice. Thanks for sharing!I got busy with my Dremel and set the little lady free.
Thank youCongratulations on setting her free. She is looking very nice. Thanks for sharing!
Regards
Rick
Your suggestion worked great.I used a small piece of excess chain plate material, sharpened it to look like a wedge and fiddled and fooled around as long as it took me to get the strip through.
It was by no means a straightforward process but it worked.
PS You'll also need those strips to align the holes for the chain plates in the monkey- and buffalo rails with the outside skin...
I painted all the rails and waterways prior to assembly, while masking the bond area.Should I paint the waterways and bulwark interior pri of r to installing the rails?
Tex
That's a sound idea.Should I attempt to devise a fixture with some spare wood.
