Well it's more refined than the $50 dollar ones on Amazon but the outcome will probably be the same with the cheap ones. If you have a decent set of cutting tools all the machine has to do is spin the wood.
PROXXON MICRO LATHE DB 250 with accessories - UNBOXING
(with examples of woodworking)
Yes your right the Proxxon has 10" between centers not bad for a small machine. But will a little red-neck engineering the 50 dollar one could be stretched out to 10" or more.![]()
quoteYes, but I was pointing to the benefits of using a "longer" piece of wood, that can be introduced through a back hole, like in much more expensive lathes. You can see that on the video. Nevertheless, when you start to add and modify your $50 I bet that the margin to the $200 is significantly reduced, and it will never be the same tool.
Cheers
Daniel
Ps: there are green and red apples. Both are apples, but they taste diferent.![]()
Nice work. Do you happen to know what the thread size is for the shaft the chuck mounts too ?I converted my $50 lathe to hold 22" pieces. I also cut a little "V" block to hold the center straight when working with longer pices.
View attachment 458382View attachment 458383
https://www.amazon.com/gp/product/B074MN2CPL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Thank you for the review. Well done as always! Never too many tools!PROXXON MICRO LATHE DB 250 with accessories - UNBOXING
No Bob. I don't even know how to get the chuck off. Do yo know how?Nice work. Do you happen to know what the thread size is for the shaft the chuck mounts too ?
It must just screw off probably with left hand threads.No Bob. I don't even know how to get the chuck off. Do yo know how?
I haven't tried vice grips on the shaft. Pliers don't grasp hard enough. There's not a lot to get a bite on. Are there any different heads to use with the $50 lathe?It must just screw off probably with left hand threads.
It must unscrew. I was wrong when I said left hand threads it must be regular right hand thread that way it won't unscrew it self. It you look on the web you'll see other brands of these cheap lathe and some come with small face plates 3 and 4 jaw chucks and sanding disks so they must all be built the same way. You just have to figure out what thread it is and search for mini lathe attachments.I haven't tried vice grips on the shaft. Pliers don't grasp hard enough. There's not a lot to get a bite on. Are there any different heads to use with the $50 lathe?
View attachment 458393View attachment 458394
But. still the Proxxon seems to be a nice small lathe for the price. Looks like around $250-$300 with the accessories.
