The lower are round, the upper …… see picture above …….It appears to me that the deadeyes are round and are shrouded with a protective cover.
Best regards
Ted
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Best regards
Ted
There are no original detailed drawing left that show those parts of the original BN.Maybe someone has a contemporary drawing that will show this for sure.
You have to trust on the old pictures……… That time they had no Photoshop…..Not 100% sure ……
Yup, looks heart shaped.Not 100% sure but they look to be 7" X11" so not round. Maybe someone has a contemporary drawing that will show this for sure. American fishing schooners appear to have had round deadeyes and sizes varied from about 5" to 7" as explained by Howard Chappelle in The American Fishing Schooners, Perhaps Gloucester fishing schooners were different, at least for Bluenose.
Thanks for your photos and inputThere are no original detailed drawing left that show those parts of the original BN.
Good morning Ted. Looking good. I like that you thinned the stain/ploy as it keeps the wood colour more. Cheers GrantFirst coat of stain on the hull frames . I thinned it out hoping to lose some of the opaqueness I got on the deck beams. I'm liking this tiny better.
Best regards
TedView attachment 465634View attachment 465635
Yes even though a little splotchy. Slow and easy and less is more.Good morning Ted. Looking good. I like that you thinned the stain/ploy as it keeps the wood colour more. Cheers Grant
In my kit they are all the same size within .002". Indistinguishable if you consider out of round.Hi Ted.
The 6 of D245 are for the Main / Captains Cabin. See plan 8-3, fig. P.18
The 2 of D246 are for the Hawse Holes. See plan 8-2, fig. 27.
The 2 of the 3 of D247 are for Stearing Case. See plan 8-3, fig. P.19. The 3rd is for the Main Cabin door. See P.18.
For example, when you use the Google Translate app, the parts list for the Chinese characters shows this translation text as indication:
Hi Ted, I used the same technique as the bow plate but this time the letters are raised so the paint stays in the lower flat background. Note that the brass name plate is of the same type used on the Bluenose II. The original Bluenose which you are building should look like this picture below. In your kit there should be a small plastic bag with this decal in it which is period correct.
View attachment 465898View attachment 465899
Should look like this from Deans model.
I'm baffled.  Both of these gears were manufactured with a slot at the center of the gear.
Panic is over. I figured it was.I don't recall having any problem with this Ted. Not sure what to say, I did buy some extra plastic gears so I could make the bull gear coming out of the engine box. I think I just ignored the gap, having said that the only reason I can think of for it is to serve as an expansion opening.
