- Oct 1, 2023
**VIEW THREAD HERE** |
Looks about right, but when in doubt, check with the drawings.The stovepipe, motor box and anchor rope container are not glued in place. I'm having trouble deciding if they are correctly positioned.
Please let me know if they are incorrect. I'm not glueing them until tomorrow.
Best regards
Ted View attachment 466552View attachment 466553View attachment 466554
I was following the instructions pamphlet except for skipping over the deadeyes,which are intimidating me.Before you move too far ahead, the bowsprit may be one of these pieces requiring an early install as to avoid big problems later on.
The drawings and deck fixtures don't seem to completely line upLooks about right, but when in doubt, check with the drawings.
The bits and all winch parts on the fwd deck are obstructing a later installation of the bowsprit, assuming you're installing this part from the inside out, instead of from the outside. This also depends on whether or not you taper the bowsprit ánd the diameter in the railing.I was following the instructions pamphlet except for skipping over the deadeyes,which are intimidating me.
Is their an advantage of putting the bowsprit in now.
I've been avoiding installation of anything that projects from the hull so it doesn't get broken. I haven't looked at the bowsprit instructions yet.The bits and all winch parts on the fwd deck are obstructing a later installation of the bowsprit, assuming you're installing this part from the inside out, instead of from the outside. This also depends on whether or not you taper the bowsprit ánd the diameter in the railing.
In all honesty, my bowsprit was definitely not in accordance with the YQ-drawings, preventing installation from the outside.
Thought I noticed something like that in your pics, but contributed that to fotographic distortion.The drawings and deck fixtures don't seem to completely line up
I don't think it really makes any difference as long as I don't crowd the rails and make rigging difficult.
Best regards
Ted
I understand your reluctantly, but sometimes one has to accept that it's not always possible to continue without compromise.I've been avoiding installation of anything that projects from the hull so it doesn't get broken. I haven't looked at the bowsprit instructions yet.
Thank you
Ted
Fortunately, I never had a catastrophic event with regards to the bowsprit...![]()
I'll start my research today.I had tapered my bowsprit such that its installation had to be from the inside. This meant I had to set it prior to setting part 171, (not to be confused with part C171). Unfortunately, I never found this piece called out on the 1:1 (except in the parts sheet 8-8) or in the booklet however it is partially shown but not labeled on the 1:1 sheet 8-5 in the upper left corner in the box labeled "I". This part covers the bowsprit. Part C171 is a completely different piece that glues to the bowsprit itself.
Good Luck.
Great Idea!I don't know how to layout the eyebolts on the bowsprit laterally and perpendicular to each other accurately so I glued a little square on the end so I can rotate it properly.
Best regards
Ted View attachment 466896
Thank youGreat Idea!
