- Oct 9, 2020
I was wondering if anyone has painted their hull with copper paint instead of gluing on copper plates, and if they found that it looked good?
AgreedMy first model, about 1973, was a solid hull clipper ship. I painted (by brush) the hull below the water line with copper paint from Humbrol. Still looks great in its glass enclosure and is still one of my favorite models. I have done several ships using copper plates and would probably use them again in lieu of paint, but the painted ship worked out quite well. I was not aware of plating at that time. Painting is much, much less labor intensive!
I used that copper tape that is used for stainglass hobby. I didn't have anything on the wood. So you are thinking that I need to put some varnish or something on the wood before putting the copper tape?Just wondering about your plates not sticking Jack. I had no idea what I was doing and mine stuck well. Did you put some kind of finish on the planks before you tried to copper the bottom? I used a couple of coats of shellac on the Discovery before I coppered it.
Ok. ThanksYeah. I think the tape I used was for keeping slugs away from plants but it all probably comes off the same machine. I do think that it would stick better to a smooth surface. Stick a piece to a window and then stick a piece to a Popsicle stick and see which sticks better.
Corsair's comment regarding the importance of scale is on target. Once again, we are addressing matters of accuracy, appearance, and the physics of scale. The process of attaching individual copper bits to a model may be "accurate" as it roughly represents the process of attaching copper to a vessel. However, is the thickness of the copper to scale (probably not, since copper sheathing was pretty thin)? Does the completed sheathing look like what one would see on an actual vessel? The first picture below is of the Cutty Sark on display in Greenwich. You can discern a pattern of plates on Cutty Sark's shiny new copper, but they are not nearly as pronounced as those shown in post #3.Part of the response depends on the size and scale of the model.For instance, I would not want to try to plate the bottom of the hull of the Constitution with individual plates in 1/196 scale.
However, if it is a larger scale, say 1/64, it will be hard to beat the realism of individual plates. But, painting can be done to wonderful effect !
I like the painted look.Corsair's comment regarding the importance of scale is on target. Once again, we are addressing matters of accuracy, appearance, and the physics of scale. The process of attaching individual copper bits to a model may be "accurate" as it roughly represents the process of attaching copper to a vessel. However, is the thickness of the copper to scale (probably not, since copper sheathing was pretty thin)? Does the completed sheathing look like what one would see on an actual vessel? The first picture below is of the Cutty Sark on display in Greenwich. You can discern a pattern of plates on Cutty Sark's shiny new copper, but they are not nearly as pronounced as those shown in post #3.
Second and third pictures are of a simple half-hull model of the Dapper Tom in 5/32" scale. The rough-carved, solid hull was rescued from the reject box at the old Model Shipways shop in Bogota NJ. I painted her below the waterline with copper paint with some green worked in to represent verdigris. If memory serves, I used Testors enamels in the little square jars. I think this is fine for such a small, simple model.
So, each modeler gets to make their own choice. Fair winds!
View attachment 467595View attachment 467596View attachment 467597
I am building my second Revell 1/96 Constitution; with the detail on the hull, I used Testors copper paint on both hulls and they look great, brushed on.I was wondering if anyone has painted their hull with copper paint instead of gluing on copper plates, and if they found that it looked good?
They certainly are better looking than the usual "store-boughten" ones!I am using the plates from Amati. It is a lot of work, but I think I am liking it.
