- Oct 1, 2023
I have no idea. I'm just going by the parts supplied in the kit and the plans.Hi Ted
Considering the era and type of vessel shouldn't the anchors be iron stock anchors or maybe bank anchors?
Thank youT
That's looking much better than your first try.![]()
Maybe you can still convince Ted? But seen his post above I don’t think so.I understand, but these are really easy to make, even if completely out of wood and paint, with hand tools.
AllanView attachment 467683
Hi bro, you have a scratch-building bugI understand, but these are really easy to make, even if completely out of wood and paint, with hand tools.
I don't understand. You want me t scratch build some new anchors and throw away the ones I've already built.I understand, but these are really easy to make, even if completely out of wood and paint, with hand tools.
Hi Ted,You want me t scratch build some new anchors and throw away the ones I've already built.
ThanksAs far as I'm aware of, the Bluenose didn't have portholes in its wheelhouse. So you could happily do without them.
There should have been 2ea. 3d printed ships wheel in your kit. YQ may have run out of them though.The part 16 doesn't fit as a top for steering wheel box!!!
And, the steering wheel came as a piece of costume jewelry with a cast in hoop for the chain. I ground the hoop of but it was formed from the side of the spoke handle and left a flat spot. The wheel appear to big for the steering box. I'm going to get busy reviewing some build logs to see if I'm crazy again
. best regards
Ted View attachment 468429
I installed the veneer parts but my kit did not come with the prescribed port holesThe long edge of the wheelhouse interfaces with the deck, the length of the shorter, opposite edge should match the the length of the wheelhouse cover.
The kit should also hold two 0,5mm veneer parts, matching the inscribed lines. They're on the dories part tree.
