Parts review Drydock Models and Parts - Photo Etched parts: Part 1/2
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
Photo etching, also known as photo chemical machining or chemical etching, is a manufacturing process that uses corrosive chemicals and photoresist masking to create thin metal parts. The history of photo etching can be traced back to the early 20th century when it was used to create intricate designs on jewelry and decorative items. It became a game-changing manufacturing technique in the middle of the century, and modern chemical etching began with the invention of photoresists in the 1950s.
Photoetched parts are tiny metal parts that are used to add detail to models. Using a chemical process, they are made by etching a metal sheet, such as brass, stainless steel, or titanium. The process involves covering a light-sensitive emulsion with a photographic negative and then washing away the unexposed areas. The remaining areas are then eaten away by acid, resulting in the desired design. Photoetched parts are commonly used in model making and miniature engineering and are particularly useful for adding fine details that are difficult to produce with plastic. Some examples of their use include:
- Military modeling: Adding details like grilles, hinges, latches, and handrails
- Building Gundams: Adding surface details and covering locating holes
- Model ships: Photoetched parts are often used for model ships due to their extremely small scale
- Cockpit detailing: Photoetched parts are ideal for cockpit detailing and other fine details that are too small for injection or resin molding
- Light blocks: Photoetched parts can be used as light blocks in small or tight areas of a model that will be lit
Greetings, folks, you guessed it right. Today's review of the Photoetched parts. I have just some of the PE parts from DryDoc in my possession, which I will review in the following posts. But... if for some reason, you didn't read my previous reviews on mini-kits, please follow the links below. I would be curious to know your opinion, hence, you may already bought and used them in the past.
Today's topic for the review is the Gunport hinges. The gunports were sealed by the gunport lids. In the 15th Century, these were simple timber boards, which were placed over the ports on the inside, and secured with a locking bar. The invention of the gunport lid suspended on hinges and closed with lanyard dates from the early 16th Century and is scribed to a French master shipwright. As said earlier the gunport lids are suspended on hinges.
The hinges' designs and shapes have varied over centuries from the origin they were made. While some of them were fancy, others were just simple designs technologically they built the same and suited only one purpose - to suspend the port lid.
Gun port in detail with parts and layout
DryDoc's hinges were suitable based on British design from the 18th century. They come on the fret by 5 pairs (total 10) and will make hinges for 5 gunport lids (2 for each port). As with most PE parts, from DryDoc, the hinges are designed for 4 common scales: 1:48, 1:64, 1:72, and 1:96
Macro images to get an impression of quality. I like the embossed bolt imitation: no need to drill holes for the bolts.
The hinges are designed for 'static' mode, other words, not function for opening/closing. You will have to decide how you will show your gun port: closed, opened. Now, let's see what you can do with those hinges. Please note, that all the hinges are designed the same, so no need to show all the scales. However, I will be using different scales interchangeably in my tutorial.
The first step is to remove the pair from the fret, and clean flushing. As you can see, even with embossed bolts, the hinge itself looks 'flat'.
With just a simple trick, I will make it look much better, IMHO. First, I anneal, do not anneal the entire part as it will get soft, only the top portion. Once the part cooled, place it on your cutting mat (doesn't have to be Green :p), the next task is to find the suitable diameter drillbit and place it on top of the hinge. Make sure the drillbit is parallel to the cutting mat surface and 90 degrees to the entire hinge. (see images below). Lightly tap on the drillbit, the part should bent a bit, keep an eye on the drillbit position. make sure it is parallel to the matt and tap again. Continue until satisfied with the shape.
This is the simplest method to bend, IMHO, and doesn't require special tooling, but... if you plan to make hinges for 100+ ports, I suggest making a simple jig similar to the one on the next image. The results will be uniform for all of your hinges.
At this point, they look much better than flat, but ...something else can be done, and I will let you find from the following images. I am sure you guessed it right, I added a bolt. I use tiny nails from DryDoc and solder them. As you can see, now they look like real hinges even though they are fake.
both images for comparison
I mean this is it! With a small effort and minimum tooling, you can make cool-looking hinges. But... if this is not yet convincing you, check this out... I made my working hinge using the main parts from a PE. Making 100 + working hinges would require a different process ... or maybe not, but... I found some brass tubing and wire, said 'Trimbly, Sumbly, Boom, and here is the result.
The parts are made from tubing and wire
here is the proof
...and the final images on the next post due to a limit of 25 per single post
Dimensions for the gun lid hinges:
Continue on the final images ...
On the right - the working hinge, in the middle - static and blackened, on the left static as is, (for all hinges I added rings to hold the rope while raising the lid port.
Here, I opened a static port, permanently. No way to put it back closed.
One of my models asked to participate in the photo session, I couldn't resist...
Here is the model itself, it is 100 % made from naval gun mini-kits found in the DryDoc store
Conclusion:
Great product for those of us who are looking for aftermarket lid hinges. With a bolt imitation, you don't have to break many drill bits to drill the tinny brass plate. With a relatively small effort, it could turn a very presentable hinges. You can even use the base stock and make those hinges work ;) ! From the downside, I wish they could be a bit thicker material, but maybe it is just me. Other than that, I like it!
If my review help you to make a decision, you can buy the gun lid hinges here:
Let me know what you think. Maybe you already use it, I would love your opinion. That should be it... for today. Thank you for watching and participating... See you soon, we will review more PE parts.
Very good review and also somehow already a tutorial - very good work my friend
and btw: great hinges - I want some!
btw2: how did you make these small rings?
are these eyebolts or ?
Thank you very much, Uwe!
If you look at the image with all thee gunports, the small rings on the left are eyerings from the 1:64-scale PE fret (two eyerings already missing ;)). I will review eyerings and hooks in my next review. For those in the middle and on the right side, I made them from scratch using 0.4mm brass wire.
I am assuming the eyebolts or holes at bottom of hinges are for ropes used to pull the lid open.
you are correct, Kurt. Both outside rings are to open the port lid, while the single ring inside the lid is to pull it back to closing. Did you see the small video clip (above)?
An excellent tutorial with great explanations and photos. I’ve used PE before and agree the parts can really enhance models, especially after tweaking and blackening. Or, as you say, “Trimbly, Sumbly, Boom” ROTF.
I recently purchased hooks from Dry-Dock (and pear blocks) to use on carronades. I look forward to your next review, thanks.
(The video link in your post only shows a black square for me, with the words “This video is private”. Could be because I’m on an iPad).
Thank you, Roger. The video should be available to those who have the link, anyone on the forum should have access.
I wonder if anybody else has trouble, Can someone confirm the video can be viewed?
Dear jimsky
An excellent tutorial with great explanations and photos. thank you very much my friend
