LOG LONGBOAT ANCRE LEMER 1:24
CONWAY SPRINGS, KS
ERE IS THE START OF MY BUILDING LOG OF THE LONGBOAT MIKE41 IS ALSO DOING THIS BUILD BUT IN SMALLER SCALE. AS MIKE IS A MASTER I WILLO POST TEXT AND LET MIKE SHOW THE WAY IT SHOULD BE BUILT I WILL POST QUESTIONS THAT I HAVE ALSO I HAVE BEEN RETOOLING IN THE LAST COUPLE OF MOS. DUE TO VERY BAD EYESIGHT WILL SHOW THE TOOLS AND WHAT I CAN AQCOMPLISH BETTER HOPE IT HELPS OTHERS. GOD BLESS STAY SAFE ALL DON
HI EVERYONE HERE GOES THE PICTURES ARE VERY BAD NEW TABLET ON ORDER BUT HERE GOES AS STATED BEFORE NOW FOR SOME SOLUTIONS TO BAD, BAD EYESIGHT HAD A LOT OF PROBLEMS GETTING PAPER PATTERENS CORECT THE OLD WAY TURNED OUT ATROSIOUS SO ORDERED LEXON CURVED SCIORIS, NIB PEN TO OUTLINE PATTEREN LEAVING SOME MEAT FOR FINAL SANDING COMPOUNDING PROBLEMS IS LAYOU5T FOR FRAMES MY SCALE IS 1:24 HOW IN THE HELL IS MIKE41 DOING HIS FRAMES IN 1:36 DIFFERENCE BETWEEN MASTER ANDN APPRENTICE SO HERE ARE SOME PICTURES . GOD BLESS STAY SAFE ALL DON
Hi Don. Looks like you are off to a good start. It looks like you started with frame number 7, you should mark the frame as 7 F or 7A, for the forward frame or aft frame due to the way the frame are numbered.
This is a copy of my frame distribution drawing you can use as a reference.
Mike
Hi Don
great start, I will keep following with great curiosity and support :) Thumbsup
THANK YOU ALL KURT AND BRYAN LIKE I SAID BEFORE FORWARD FRAMES ALMOST DONE WITH FORWARD FRAMES STILL HAVEING A GOOD TIME WITH THIS M EVEN THOUGH I AM THE TORTASE WILL NEVER CATCH THE HARE QUESTION FOR MIKE41ON PLAQTE 4 FIGURE 4 AND 5 IT SHOWS FRAMES LABELED MG WITH A SPACE BETWEEN THE SPACE I ASSUME IS MIDSHIP BUT CAN NOT FIND FRAME DRAWINGS ON FRAME SHEETS. GOD BLESS STAY SAFE ALL DON
Hi Don, sorry I did not get back sooner, we went to a birthday party at Pawleys Island for my son-in-law last night and got back home late.
Plate No. 4 Figure 4 Shows the evolution of the rabbet at different stages up the sternpost though a series of sections. Does not pertain to frames.
On page 29 of the instruction manual Plate No. 1 shows M.G. as the high point of the keel.
On page 40 of the instruction manual Plate No. 5 has the pattern for M.G. Av in the upper right corner of the page.
Note: The after frame M.G. Ar, pattern is located on page 42.
Mike
