Thank you Sir.One last thing to do is go over it with Bees Wax before removing the rope from the walk.
I can't say anything about Guterman Skala 240 threads, but I didn't like Guterman Skala 360 threads, they are too thin, which makes them hard to work with, and for some unknown reason, ropes whiter than 0.6 mm turn out to be unevenly twisted. It is poorly visible in the photo, but in nature it is clear that the rope is not evenly twisted.You can find other types like Guterman Skala to be excellent.
The uneven texture/bumps you are encountering are because you need more pressure on the strands while twisting and laying them up. Skala can handle quite a lot of weight.I can't say anything about Guterman Skala 240 threads, but I didn't like Guterman Skala 360 threads, they are too thin, which makes them hard to work with, and for some unknown reason, ropes whiter than 0.6 mm turn out to be unevenly twisted. It is poorly visible in the photo, but in nature it is clear that the rope is not evenly twisted.
Thanks for the hint, I will try.The uneven texture/bumps you are encountering are because you need more pressure on the strands while twisting and laying them up. Skala can handle quite a lot of weight.
I have a vertical cable car, the height of the doorway for 1/72 scale models is quite long enough for me.All good information, thank you! Question: What is a recommended or good length to make your ropes in? It would seem that a table of 3-4 meters would be needed and I do not have the room for that long of a table. Cheers!
I use a damp cloth.One last thing to do is go over it with Bees Wax before removing the rope from the walk.
I have seen in some posts that people wrap the rope around a can and heat the rope in the oven at low heat. Do you find a need for that as well?I use a damp cloth.
The only question is what will happen after the "roasting" with the rigging in 10-20-30 years.I have seen in some posts that people wrap the rope around a can and heat the rope in the oven at low heat. Do you find a need for that as well?
@Winter , what is the color code of the ropes you show in your last picture? is it the 464?I can't say anything about Guterman Skala 240 threads, but I didn't like Guterman Skala 360 threads, they are too thin, which makes them hard to work with, and for some unknown reason, ropes whiter than 0.6 mm turn out to be unevenly twisted. It is poorly visible in the photo, but in nature it is clear that the rope is not evenly twisted.
I've never tried it, as I use mostly cotton. If I use poly, then a spot of ca seals the ends, same with cotton.I have seen in some posts that people wrap the rope around a can and heat the rope in the oven at low heat. Do you find a need for that as well?
Heat-treating rope will help them from unraveling. It does make them more stiff and difficult to use. Don't go over 300F and don't leave them in there for more than a few minutes.I have seen in some posts that people wrap the rope around a can and heat the rope in the oven at low heat. Do you find a need for that as well?
When they make the polyester thread it starts as pellets and is heated and stretched into small fibers. I have seen one process that used chemicals.The only question is what will happen after the "roasting" with the rigging in 10-20-30 years.
