The rudder trunk in combination with the following curve of the planking look (as usual) very nice, Paul.An easy thing and two hard things...
Moving now to the back of the ship I have planked the inside surface of the counter (an easy thing) and added a sill for the stern lights. The sill qualifies for a hard thing. It has to be level to the keel, account for the curved shape of the lower transom, and fit around the counter timbers. I was able to achieve a pretty nice fit where the sill will be visible - and the window frames will hide the areas where I wasn't able to get a good fit on the sides of the transom timbers:
The other hard thing was the rudder trunk. This mini-construction has too many planes and curves intersecting in three dimensions for it to be even remotely enjoyable to fabricate. A responsible forum member would have taken pictures during the construction, but I have failed you in this regard.
Here is what I ended up with:
All in all, I'm satisfied with this outcome.
And yes, it does have a bit of an Iron Man vibe:
