Thanks all- great discussion and informative.
to me, it is fully correct for a British ship. the Oriental ones, somewhat differentI had looked at many pictures of guns rigging from HMS Victory museum. I cannot understand how the thin rope rigging with blocks and hooks is designed. Is each one with two double blocks or it is with one double and one single block? It also looks as the loose end is being threaded through hook rings on each end. After that end is thied over the center of the rope rigging bunch. Am I correct? Please help. Here is sample picture.
The loose end would be moving at enormous speed, whipping around like a striking rattler and if it were to snag or tangle, something would have to break.just allowed to run free when the cannon fired.
alltough no terms, it is easy to undrstand-el capiThis is now a bit old, but where did the below photo that is in post #7 above come from? I would like to get the table of terms that go with the numbers, especially the part marked 10 on the port tackle set up to see what it is and its purpose as I have no idea what that is.
Thank you!
Not for everyonealltough no terms, it is easy to undrstand-el capi
Finally I found out, why there are 2 rings in the back of the carriage.HI there
I was looking at some images of HMS Victory 12 pounder cannon and noticed that gun hoist tackle is hooked onto eye bolt on top and at rear of carriage. Other resources provide here show tackle hooked on to side eye bolt (as indeed are some of Victory's other cannon? Which is correct?
Thanks
If you are referring to the block 25 I think it is hooked in the wrong place. Then again, maybe when the gun was secured they might have been used as the train tackle would be removed.Finally I found out, why there are 2 rings in the back of the carriage.
Hi RolandI assumed as well, it was only used to secure the carriage from moving sideways while underway. The lines are neatly wrapped, which also indicates, this gun is not ready for engagement.
