Rigging of guns on HMS Victory
  • Thread starter Thread starter Y.T.
  • Watchers Watchers 13
I had looked at many pictures of guns rigging from HMS Victory museum. I cannot understand how the thin rope rigging with blocks and hooks is designed. Is each one with two double blocks or it is with one double and one single block? It also looks as the loose end is being threaded through hook rings on each end. After that end is thied over the center of the rope rigging bunch. Am I correct? Please help. Here is sample picture.
to me, it is fully correct for a British ship. the Oriental ones, somewhat different
HI there
I was looking at some images of HMS Victory 12 pounder cannon and noticed that gun hoist tackle is hooked onto eye bolt on top and at rear of carriage. Other resources provide here show tackle hooked on to side eye bolt (as indeed are some of Victory's other cannon? Which is correct?
Thanks
12-pounder-gun-on-forcastle-of-museum-ship-hms-victory-portsmouth-historic-dockyard-hampshire-...jpg
I believe this is incorrect. The outhaul tackles would be unhooked before firing which is why they are fitted with the quick release hook.
The breeching rope alone contained the massive recoil.
Thanks Smithy. Always wondered about this, i presumed that tackle was not tied off or belayed and just allowed to run free when the cannon fired. If this was the case, there would be no need for a hook…
Anybody have a view on which eyebolt was used- the one on side of carriage or at the rear?
The loose end would be moving at enormous speed, whipping around like a striking rattler and if it were to snag or tangle, something would have to break.
Not if it was long enough? The hoist tackles have so much rope the end is often coiled on the deck.
These are riggings about 1795 from Congreve's Treatise on the Mounting of Sea Serviced Ordnance for a gun run in, a gun run out and secured, and a gun run in, secured, and housed. There are lists of tackles including length of breech line, etc. These sketches show the breeching and running out tackle, do not show the train tackle. Train tackle origins are obscure but they came into use between 1743 and 1765 based on the proportions of stores wherein three tackles per gun were given, the third being for the train tackle. (Caruana, The History of English Sea Ordnance, page 387)
Apologies, I do not recall the source of the below, but believe it is late 18th century
This is now a bit old, but where did the below photo that is in post #7 above come from? I would like to get the table of terms that go with the numbers, especially the part marked 10 on the port tackle set up to see what it is and its purpose as I have no idea what that is.
Thank you!
Got the answer from another member here at SoS. There is the one port tackle that goes to an eye that has lines going to two rings on the port lid.
Thank you!
alltough no terms, it is easy to undrstand-el capi
Not for everyone :) What are items 3, 21, and 22? I can figure out 3 (I think) but have never seen this on any contemporary models or drawings, thus curious. Maybe a top view would help explain what these are.
Thank you
HI there
Thanks
Finally I found out, why there are 2 rings in the back of the carriage.
If you are referring to the block 25 I think it is hooked in the wrong place. Then again, maybe when the gun was secured they might have been used as the train tackle would be removed.
To add to the confusion, in addition to the breeching ring, earlier carriage brackets had two loops on each side instead of one. What was the purpose of the second loop?
Armstrong era carriage
I assumed as well, it was only used to secure the carriage from moving sideways while underway. The lines are neatly wrapped, which also indicates, this gun is not ready for engagement.
Hi Roland
Not sure what drawing and what part you are referring to.
I did find the top view of a drawing that is quite similar to the above originally shown in post #7. In any case this was marked as how a French gun was rigged. I have no experience in French ordnance so hopefully this is an accurate drawing. The cannon in the above version shows a loop on the cascabel like on a Blomefield pattern gun but this is not shown on the drawing below. I wonder if the above version is something of a copy and then modified so it is supposedly an English pattern gun. If that is the case it is not a good drawing to follow for English ships. If nothing else, the train tackle was a single on English ships. It would have a single block and a double block for 32 pounders and two single blocks for all guns smaller than 32 pounders.
