I'm a bit surprised to be posting again this weekend - but there was lots of modeling time that I was able to take advantage of.
Plus, the work completed was enormously gratifying! The planking is DONE!
I installed waterways to the forecastle deck and quarter deck - and then added the final planks bringing the inner bulwark to the level of the planksheer (is that the correct term?).
Quality clamping is underrated :):
It was now time to refine the height of the inner and outer planking so that the cap rail will sit level (I have a problem at the waist that will require some work but otherwise this process went well):
And of course that meant I needed to add treenails. The final count is about 13,000 on this model:
And now on the painted side:
Again, seeing the ship arrive at this stage is enormously satisfying!
And I thank you for stopping by!
Good evening. Freak Paul- this is so good! Said it before you have skills a plenty. Cheers Grant
Paul, somewhere in this epic log you must have described your treenailing techniques but I can’t find it. In a sentence, what’s your method?
But for a great tutorial on making treenail stock check this out...
Thanks Paul. That's very helpful and taught me a lot that I didn't know I didn't know.
Incidentally, a hundred pages back I see that you got married - Congratulations!!
I also noticed how your woodworking has improved since then, the difference is quite striking. Please tell me I don't have to get married to improve my jointing. :eek:
Don't tell my current wife (39 years)...
Oops.
And yet...
My bride and I are headed to Yellowstone / Glacier National Parks for some sightseeing and hiking.
...not my fault.
Incidentally, are you aware of the traditional Royal Navy toast "Gentlemen, to our wives and sweethearts!" to which the reply is "May they never meet!"
My attention now turned to outfitting the quarter deck. This first post will feature: coamings with gratings, a ladderway, and a companion with top. In a second post I will review the ship's wheel.
Of course, I have shown coamings under construction previously. But it is always good to remember that everything must be square:
Square, that is, unless they have curved tops:
Components:
The companion has a top on it. My options were to either have a pitched roof skylight as we often see on models - or a curved top clerestory-style light. I chose the latter:
And my signature style broken gratings showed up here as well:
Ladderway:
And here are these components sitting loose on the quarter deck:
Stay tuned for a second post featuring the ship's wheel...
I started with the kit provided steering wheel...and quickly discovered the central hub was not provided. Of course, it is no great difficulty to make a circle with a hole in it:
I then added the kit-provided spokes and the outer ring:
I wasn't too excited about this look, so I tried to round off the outer ring:
Hmm...not exactly a high-precision outcome :(.
After a bit of research and the accumulation of the requisite level of courage...I decided to give it another shot, but this time using milled parts. I created four 'worktables' that would fit into the dividing attachment of my mill. Each of these 'worktables' had a boxwood board attached to it with rubber cement (three with 1 mm box and the fourth with 2 mm box):
Time to make some circles:
All four:
Now I needed to mill 1 mm slots in the 2 mm board to receive the spokes (every 36 degrees):
Here is the 2 mm hub and the 2 mm outer ring with loose-fit spokes - the opposing 1 mm outer ring sits to the left:
So why did I make four rings? Two of the rings were just barely dimensionally narrower than the main outer rings - I was hoping to use them decoratively. Here you can see one added to the main outer ring:
Next, I thinned down this decorative ring:
Progressing...
I decided to go back and add some details to the decorative ring:
The kit-provided wheel is to the left:
Below you can see the built-up stanchions and a central barrel where the rope will wrap (I made the barrel on the mill with the dividing accessory):
And now all the parts glued together:
And finally, sitting loose on the ship:
That's two full days of my life sitting there. I have now removed this breathtakingly fragile wheel and placed it into storage.
Thanks for the visit! You are a fine bunch!
together:
Ooo! :)
All four:
Progressing...
Now that was fun to watch!
Paul, I continue to have really irritating log-in issues with this site. If I reset my password from my phone, the site will work just fine from my phone. But, if I then use THAT SAME password to log-in to my home computer, the site won’t recognize it. I can re-set my password on the home computer - even using the same exact password, or not - but then the phone won’t recognize that password. It is seriously irritating that this site is so buggy.
Anyway, though I am not often visible, I am still following along. I love all of what is happening, here!
@dockattner sorry for off top
... Before you blame the site for so many bugs, ask if anyone else has experienced such a problem. I cannot affirm nor decline that forum software doesn't have any (bugs), but, honestly..., no one else reported such an issue. I mean not another member, though.
I do really regret that you have experienced such obscured difficulties, and really would love to boil down fixing it, but it is kinda difficult to troubleshot if everyone else (I hope) doesn't have such issues.
I don't use my phone to browse SOS, but I use my PC at home, and use my laptop while on the road and never ever experience issues with login. It sounds like you may have problems with your password 'vault' ither on your phone or your laptop\pc where they both or one of them remember the password.
Sorry for the long explanation, Marc
All four:
Progressing...
WOW just doesn't seem to cover it. Storage is certainly the place for such a gem until required for the finale.
