Tigercat 880E logger 1/48 scale
Lorraine, QC, Canada
Hello everyone
I was asked to 3d model and print a pair of Tigercat logger with a custom arm at 1/48 scale. I wasn't given the green light yet but I decided to go ahead and start the project anyway. Worst case scenario, I'll have a couple of nice loggers to add to my collection. I'm not used to work at such small scale but this logger is a big machine so it will still be a good size model.
Here are a few shots of the 3d model
And a few of some of the printed parts
I'm almost done with the 3d modeling of the barge on which sits the harvester. The Tigercat is being painted and assy will start soon.
Here's what I have to reproduce.
And here my 3d model so far. Everything was 3d modeled from just a few pictures
here are the telescopic boom parts, they are very intricate but came out of the printer looking very nice
And here are some pictures of the painted parts
All I can say is wow!!!
I wish I had a 3D printer, but I have no idea what printer to buy and do not know how to use one.
Donnie, a printer is useless if you have nothing to print. The first thing to do is to learn how to use a modeling software which in itself can be somewhat daunting oooor, you could always farm out the design (wink wink) and print the parts yourself.
3D printing and modeling talent brings things to another level never seen. The possibilities seem endless. Details, Details, Details!
I have the first barge all painted and ready for detailing and final assembly. I've also made 2 bunks (2 per barge). These are submerged steel structures that receive the trees once they are cut. From what I can see on the pictures I have, the bunks are just painted with red oxyde primer ( or something that looks like it) and are very rusty. So I primed mine with a red primer and will try to rust them up a bit.
Here are some pictures of the barge fabrication.
Painted bottom section
My version of the engine
And the real thing
Top deck accessories painted and ready for assembly
engines ready for assembly
A chain ratchet binder (that's a toothpick holding it)
Top deck painted, ready for detailing with black panel edger
And a few details
Top and bottom test fitted (the gap between the 2 is for the plexiglass
more details
The bunks fab
first pair primed and ready for rusting
Test fit of bunks and barge
A speaking peek at the end result
Tell us more about these models... Were they commissioned? Where will they be displayed? Did you you work from actual plans? Are you a professional modeler?
Jwallkc, yes they were commissioned but I don't know where they will be displayed. I had a few pdf drawings for the barge and bunks but I mostly designed them from pictures. The Tigercat was all done from pictures I found on the net. I don't consider myself as a professional modeler, being a professional in something requiers many years of practice. But being a perfectionist, I usually make very nice and accurate models.
So, my part in this project is done. Tomorrow, I'll be tranfering it to the diorama guy. Here are some pictures showing a bit how everything came together.
The inner plexiglass with laser cut openings mounted in a temporary frame
Bottom half screwed in place
Anchor deflector installed
Both bunks in place
Top half screwed from underneath thru bottom and plexiglass thus locking the bunks in place
Tigercat glued onto the top surface
Firts chain ratchet binder installed
Both binder and cross braking cable installed at one end (same was installed at other end of Tigercat)
Tool boxes, front vent and front buoy installed
Anchor chain glued in place
Mast glued in place
And 3 retaining cables attached
Triton arm inserted thru plexiglass and glued in place (all pivots were also glued to eliminate any movement and rigidity the assembly)
And finally, the harvesting hand was installed after passing the cab lights wires thru
A few shots of the completed models
Hope you enjoyed following this build half as much as l enjoyed making it.
