A certain guy who wrote a book about swan class ships also pointed that out - so you're in good companyMmm shouldn't the spokes not be completely round? ;-)
Dirk aka Pain in the A**
PS: Just answer "no" :-D
... Working on it (and thus far failing).
Don't start a discussion about teeth around here, especially because you're British.tape you drag between our teeth
Avoid talking about teeth or before you know it we are 6 pages ahead.
Don't start a discussion about teeth around here, especially because you're British.Avoid talking about teeth or before you know it we are 6 pages ahead.
Thanks for this suggestion, Smithy; I was certainly enthralled with it! But I gave it a go on a spare spindle and the tape is too stiff. The spindles are quite small (about 0.8 mm dimensionally) and more fragile than they appear in the images.A thin strip of that abrasive tape you drag between our teeth and a delicate touch?
You only need to take the corners off for observers with normal vision to think that they see roundness.
The solution would be to pull the spindles and start over on them - that way I could work outside of the constraints imposed by the finished part (I would turn the spindles on a mini-lathe or use a rotary tool). But working the spindles on the finished steering wheel is just too risky. In this case I'm going to say that perfect is the enemy of good. I am happy to use the wheel as is and will do a better one the next time.
I think it looks great! As far as historical accuracy goes… AL and what is deemed feasible, is often triumphant over it!Thanks for this suggestion, Smithy; I was certainly enthralled with it! But I gave it a go on a spare spindle and the tape is too stiff. The spindles are quite small (about 0.8 mm dimensionally) and more fragile than they appear in the images.
. Thanks for the visit!I have this picture with king spokeThat’s my favourite part of your wheel then. Philosophically speaking.
Davis in The Built Up Ship Model, says there was a king spoke with some difference from the others so that the helmsman could find it in the dark by touch and know how much it was turned.
That only makes sense to me if he’s standing in front of the wheel though.
You are absolutely increasing you your lathing and milling skills, Paul. That looks very neat!Hello friends,
Work continues building out the quarter deck...
But first a short diversion to scratch the itch created by my forum friend Dirk (@Dubz Modelling World). The guns carriages have now been fitted with smaller eyebolts (the quoin will be displayed on the deck alongside the gun):
And now returning to the subject of this post: the quarter deck breastworks. This is a guardrail of sorts that sits at the forward edge of the quarter deck. It has five posts, two rails with square holes, 10 sheaves in pairs of two, and follows the camber/roundup of the deck. In other words, there is a lot going on for what appears, on the surface, to be a simple guardrail.
After spending on inordinate amount of time looking at drawings of the breastwork and imagineering how I was going to get all the moving parts placed correctly...I took out my mini-lathe and made up some posts/stanchions:
Next, I wanted to profile the edge of the rails, and I chose to do this on the small mill:
The posts pass through the rails in square holes:
And now cleaned up:
As you can see, I made up some extra posts. And you can also see that they are all different. There is a way of making a pattern duplicator for a lathe - and I should have done that a long time ago - but I didn't realize how often I would want to use it. In the end I neglected to follow the clear advice of Mr. Antscherl in TFFM in favor of expediency and am paying the price for that decision.
On we go. I then used the small mill to cut slots for the sheaves. The learning curve on this was that I need a better mill (with a digital readout), and I need a better way of securing parts to the bed of the mill (better than double sided tape). Then again, I did manage to squeeze out five usable parts from the seven that started the journey.
The rails were then bent to follow the camber of the deck, cut to their final length, and profiled on their ends:
The next trick was to drill holes in the quarter deck in the absolute perfect location to receive the pins I had placed in the foot of the posts (it might seem odd to post a picture of five holes, but this exercise was painstaking and deserved to be memorialized with its own photo![]()
And here you go:
And that, dear friends, is how you lose yourself in a model for a week. Thanks for the visit!
Your tools and skills, never mind results, being so far superior to my own, I do not require, nor do I need any apologies from you regarding the quality of your finished work. It is, in two words, splendid and humbling. I suppose you join me in my admiration of the work produced by the 18th-19th c. French Prisoners of War that produced wonders of craftsmanship, working with essentially nothing, and many of whose methods and techniques remain a mystery. As do those of the producers of period admiralty models, who, even given their official backing, produced such wonders of craftsmanship and innovation as to boggle the mind!Hello friends,
And now cleaned up:
And here you go:
