- Nov 4, 2020
of course...!Are those milled from a dowel? Holes into end grain?
Nice Phil! I 3D printed mine on my Bounty and while they came out really nice they do loose the authenticity of wooden deadeyes like these made here - imho. Cheers GrantYou could always 3D print them huh?View attachment 484750
admiralty modelling has its own rules and is based on the splendid models of the time: wood where there was wood, metal where there was metal. I try to stick to this basic philosophy, but everyone is free to use the materials they like.You could always 3D print them huh?
I've made my share from wood too. They are very tedious to make. It would be easy to slice dowels and just drill into the end grain but that betrays the strength needed for deadeyes and cutting them cross-grained takes so much time. Then they have to be drilled and notched all around. But you are correct, wood looks a lot more authentic and I have yet to use any of the printed versions. They still have to be painted to simulate the wood they emulate. It's all fun to me!Nice Phil! I 3D printed mine on my Bounty and while they came out really nice they do loose the authenticity of wooden deadeyes like these made here - imho. Cheers Grant
Plug cutter. I have a slew of them. There also small toothed cutters used to remove screws too. The problem I have is having to cut dozens and dozens. I'd rather buy them.Here’s a handy tool for cutting stock for larger scale deadeyes. Chucked up in my drill press, it cuts a 3/8” diameter plug 1-1/2” long. It cuts cross grain so is properly oriented. I used pear wood, but a hard wood like maple would work too. The plug is then chucked in the lathe, turned to the proper diameter and parted off. The edges can be chamfered or rounded off in the lathe too.
At the, risk of heresy I have found the mark-1 eyeball works surprisingly well for marking out the three holes.
Roger
I would love to meet up with you guys and Tiziano Mainardi for lunch one day. The discussions would be lively over a few (maybe more than a few) glasses of wine. I will be in Livorno again next September for two days......Ps: It was a pleasure to meet you and Tizi in person and to see your models in real life.
thank you Allan!I would love to meet up with you guys and Tiziano Mainardi for lunch one day. The discussions would be lively over a few (maybe more than a few) glasses of wine. I will be in Livorno again next September for two days......If you are ever in SW Florida, know that you are most welcome to our home.
