Santisima Trinidad by Artesania Latina - Build log
Day one, unboxing. The package arrived in good condition, well packaged and in good time coming from Spain I assume, to Washington State. Right away had an issue downloading the pdf file and emailed Art Lat and they responded shortly even on the weekend. I will begin it after the holiday. They also gave me a hobby knife. I have one question regarding the log. The next time I make an entry do I attach it to the end of this or just post a thread with the same title? Thank you.
Here is the second installation of my log, days 2 to 15. I have completed the first section of the Trinidad. It was pretty easy to follow the instructions, however, having not build an Art Lat model not familiar with their instructions, which are a lot of pictures, no words, and a glossary of terms, took me a few minor glitches to slow down and examine the pictures carefully.
At day 25 I have completed most of the frame and the planking on the lower deck. The lower deck I made a template from some thin card stock to place the planks down. The planks were given one coat of watco clear oil, one coat Watco dark walnut, several coats of Tamiya thinner and clear orange and clear yellow in a ration of 2:1:1, and several coats of Art. Lat. varnish. The next step will be to complete the deck grating covers, I am sure there is a better term for them. The framing went well although I need to be very diligent with the instructions which are just pictures.
Your work looks good so far, and as you said look at the photos in book, and look ahead, as it often helps to see a step later in the model of how it looks when done.
As for reading instructions, we are guys and we don't need no stinking instructions...ha ha.
Have fun and if you run into a problem, just just post some photos here and the fine members will try to give you an answer or suggestions on how to overcome the issues.
Bugger….I bought the same but no bottle of whiskey in mine….
From day 26 to 32 completed the upper deck and as before I made a template of card stock, to support the deck which worked okay, just had to make sure that the ends by the bulkhead were secured properly. Finished the deck as before with stain and paint and varnish. Any future builds I would look for an alternative way of indicating the butt end of deck planks and treenails. My method looks out of scale. The hull was faired and now the planking begins. I ordered a new chopping slicing and dicing tool the Ultimation and awaiting it. My previous tool was a Micro Mark chopper which did not cut very square. Will be taking a break to find warmer weather. And upon my return continue finishing up the Endurance which I am awaiting more rope which is currently unavailable right now.
Days 37 to 47. Now that the Endurance is completed but for the display case which will take place in a few months, I am able to put full attention on the Trinidad. About 1/3 of the hull planking is complete and some exterior wall on the deck completed. I have to come up with a way to eventually mount this on a stand before the hull is closed in. With spring and summer here, I will have less time to build but try to post every two weeks or so. Thanks for viewing.IMG_20250322_115212_020.jpgIMG_20250325_083515_107.jpgIMG_20250325_084051_751.jpgIMG_20250324_113127_441.jpgIMG_20250322_153914_743.jpgIMG_20250322_093745_940.jpgIMG_20250322_093640_846.jpg
About two weeks since my last post and I have continued with mostly planking. I am about half way done with the hull. I did some scoping with wood scrapers to try and even out where planks were not flush and then sanding. But I can see from the photos that there is more work to be done to it. It seems that a picture doesn't hide anything. I seem to always have problems with the transom.
IMG_20250407_143534_615.jpgIMG_20250403_130353_625.jpgIMG_20250403_130337_463.jpgIMG_20250407_143552_784.jpgIMG_20250407_143524_273.jpgIMG_20250407_143512_159.jpgIMG_20250407_143518_304.jpg
The hull planking is complete to this point and now change to cutting gun ports. After scraping and sanding the hull looks ok, and now paper templates are cut and placed for the gun ports.
IMG_20250412_112234_328.jpgIMG_20250412_112243_110.jpgIMG_20250412_112251_031.jpgIMG_20250412_112301_591.jpgIMG_20250412_112309_354.jpgIMG_20250412_112330_552.jpgIMG_20250412_112350_927.jpg
The next step per the instructions are to cut and frame the gun ports. After marking the location with the templates, I proceeded following their instructions to drill it out and use a knife to finish it. At first this took a bit of time, maybe an hour for the first one, after that I tried a Dremel bit to cut them out, but this was too harsh and hard to control, so I reverted to drilling 6-7 smaller holes then cutting/sawing them out keeping them small enough to just be able to insert the frame by pounding it in to have a tight fit. With one done only 139 more to go. It might be a while until my next post. IMG_20250419_133805_579.jpgIMG_20250419_133853_317.jpgIMG_20250419_141036_1.jpgIMG_20250419_141124_4.jpg
I have finished the three lower row of gun ports, the instructions have you continue planking and enclose the hull, which I have started. I have been pondering the placement of the guns on these lower decks. Per instructions much later the half guns are attached to a piece of brass rod, a hole is drilled into the back wall and the gun on the rod is inserted. I have some concernsas far as getting them lined up, what if you drop one, stuff like that. Will let you know what I come up with. IMG_20250601_062228_025.jpgIMG_20250601_062238_545.jpg
After some contact with another builder of the same ship, I have purchased some 1 and 2 mm brass rod, cut to length, drilled a hole into the back wall, and inserted the cannon affixed to the brass rod, epoxy, and inserted into the drilled hole and here are the results of a prototype to see how it looks and fits. I still don't like the idea of waiting until much later to mount the cannons, would rather drill all the holes to allow for cleaning out all of the debris at least.IMG_20250606_085705_314.jpgIMG_20250606_085726_116.jpgIMG_20250606_085828_547.jpg
img_20250606_085841_322-jpg.523944
I also need to come up with a way to keep the barrels in line and well centered in the gun port, the brass rod will be epoxied into the back wall.
So, I shaped a small block to fit into the opening, drill a 2mm hole in the center and pull a pointed end on it to make an indentation on the back wall and when satisfied with the angle of the gun make an indentation to drill the hole. IMG_20250606_124432_357.jpgIMG_20250606_124459_805.jpgIMG_20250606_124506_767.jpg
I am back. It has been a while since last post but in that time I have completed the hull planking. Overall it went okay, but the bow did give me some issues and does not look great, however, the hull has good lines and that part of the hull will be covered with copper plating. But with some wood filler, scrapers and sandpaper able to give it a good appearance. Taking a break for a few weeks then begin on the keel. Thanks for looking.IMG_20250907_081606_822.jpgIMG_20250907_081636_2.jpgIMG_20250907_081658_8.jpgIMG_20250907_081709_4.jpgIMG_20250907_081722_8.jpgIMG_20250907_081736_0.jpg
Next I did the keel and some work on the transom placing another layer of planks and then cutting holes for the rudder and gun ports. The next step is more planking on the hull with I think they are called rubbing strakes and some decorative pieces. IMG_20251011_085419_394.jpgIMG_20251011_085430_148.jpgIMG_20251011_085456_466.jpg
just finished more of the hull decorations, rubbing strakes, gun port ornaments, drills scuppers and some work on the bow. This posed some issues as to place the gun ports, you place a paper template on the hull and trace it for each row of gun ports, however, if you are not very exact in this you can be slightly off which can cause issues later on, which is what I found out. I unfortunately do not have the foresight to see these issues before they arise, even though I am always looking ahead at their instructions which are on a PDF file, and they do not warn you in any way to be aware of certain steps. Well, with that I h ave now finished the third PDF files, there are 15 total. At this point the next step is to paint the hull. More on that to come. IMG_20251027_102737_299.jpgIMG_20251027_152343_680.jpgIMG_20251101_115937_454.jpgIMG_20251102_062351_741.jpgIMG_20251102_062401_290.jpg
