- Oct 1, 2023
Use a drop of CA to lock the knot and clip the excess thread with a (sharp) nail clipper.Here's the starboard upper mast ratlines complete.
I need to find a better method of trimming the ratline knots.
My cheap little scissors aren't cutting it. Pun intended
Happy thanksgiving from us Americans.
Best regards
View attachment 486985View attachment 486986
Thanks, I'll try the nail clippers.Hello Ted, Just catching up on your YQ Bluenose, May I suggest that you Bea's wax your lines or ropes to take away that fussy look. I always use two planks the width of the height of the rat lines with two little nails glued to one side and redrill the other side so the two planks can be assembles together easily. Then I use two alligator clips one on each side of my shrouds. Then I tie my rat lines leaving a little line so as to be able to tighten the knots across the full length of the rat line. I then use a small paint brush to paint my knots with a little bit of diluted white glue, In a few minutes after adding the glue time to dry just a bit I remove my two wooden planks and placing the bottom up against the lower rat line I reclip them and tie the next row of rat lines. When completed the full length or height of the shrouds trim the rat lines with very sharp scissors or a set of nail clippers .
Hope this helps, Please take your time this ship building is a hobby and not a job. Things will get much faster as you acquire more experience, ENJOY.
Regards Lawrence
Rub the lines in Beeswax before you use them to reduce the fuzzyness.I took the ratlines out. They were fuzzy. The cotton material didn't have any fuzziness on the spool but acquired it during installation.
I'm going back to the materials provided in the kit.
For some reason I just can't calculate the amount of the different sizes of rope I need or the exact sizes that will fit the aftermarket blocks Im using. With the high cost from Ropes of scale, etc I can't justify the expense
Like I said, unless someone can point me to an economical alternative I'm just going to use the materials provided in the kit.
Happy modeling
Ted View attachment 487129
occre.com
I'll look them up right nowTed, I have used these thread cutters on rigging. They work well and are inexpensive. You can find them on Amazon for even less.
Rob
Threads cutter
Very comfortable and precise thread cutter, to easily cut the threads of the rigging.occre.com
I bought them from Occre.I'll look them up right now
Actually, I'm looking forward to them.If you can install the top mast ratlines, you can also do the lower mast ratlines, they're just slightly more complex.
