     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
I considered planking when I answered too. If you used exposed nails, the difference might be noticeable, but since we usually don't, I see no problem with planking. Again, though, that's just me.I seriously think that if you don't straighten it up you will regret it hugely when you get to planking the hull. Just my opinion but I would be interested to know what others more skillful than I think. I always thought that that very first stage of getting everything square to the false keel was all important.?
My initial thought is: Why bother? While it's nice that bulkheads are square to the keel, having them off a bit will not change the contour by any real amount. (By my measurements, the bulkhead is less than 2% off, so width would be affected by less than 0.1%). Strength will not be affected. They will be covered, so no way to see the error after completion. And any fixed result may not be as strong. So, I wouldn't bother changing it. But then I'm lazy.
Right. To give it some numbers, a 2 degree out-of-square plank would narrow a 6" wide model to 5.996" (4/1000" narrower). Heck, 5 degrees out of square would only go to 5.977"m about half a millimeter. And that's at the maximum width, with less difference elsewhere, and the ONLY change would be the width. I can see no world where that would matter (except for those that would say, only during construction photos and not afterwards, "Oh, I see you didn't get that square!"I actually think you are right, Signet. The fairing, planking and sanding processes will all probably introduce much bigger errors than the slightly off-square bulkhead. But then I'm lazy too.![]()
