Thank you, Mirek!Witaj
Pięknie Pawle wykonałeś te elementy . Pozdrawiam Mirek
Paul, I'm slowly making progress through your wonderful build log. Now on page #159. I have to say your ship's wheel may be one of my favorite elements of your build! Masterfully done, conceptually as well as the execution. Certainly a few quality brackets above the kit's wheel. Speaking of wheels. The wheels inside that big brain of yours must always be turning. Thanks for sharing your thoughts and approach on this important element. Very valuable stuff.I started with the kit provided steering wheel...and quickly discovered the central hub was not provided. Of course, it is no great difficulty to make a circle with a hole in it:
I then added the kit-provided spokes and the outer ring:
I wasn't too excited about this look, so I tried to round off the outer ring:
Hmm...not exactly a high-precision outcome.
After a bit of research and the accumulation of the requisite level of courage...I decided to give it another shot, but this time using milled parts. I created four 'worktables' that would fit into the dividing attachment of my mill. Each of these 'worktables' had a boxwood board attached to it with rubber cement (three with 1 mm box and the fourth with 2 mm box):
Time to make some circles:
All four:
Now I needed to mill 1 mm slots in the 2 mm board to receive the spokes (every 36 degrees):
Here is the 2 mm hub and the 2 mm outer ring with loose-fit spokes - the opposing 1 mm outer ring sits to the left:
So why did I make four rings? Two of the rings were just barely dimensionally narrower than the main outer rings - I was hoping to use them decoratively. Here you can see one added to the main outer ring:
Next, I thinned down this decorative ring:
Progressing...
I decided to go back and add some details to the decorative ring:
The kit-provided wheel is to the left:
Below you can see the built-up stanchions and a central barrel where the rope will wrap (I made the barrel on the mill with the dividing accessory):
And now all the parts glued together:
And finally, sitting loose on the ship:
That's two full days of my life sitting there. I have now removed this breathtakingly fragile wheel and placed it into storage.
Thanks for the visit! You are a fine bunch!
Thanks, Ken. It's a fun retrospective as I watch you liking your way through my past. I'm not always so great about showing my work processes but I made it a point to on the wheel because I believe anyone with a mill could create a really nice ship's wheel for their build. As the saying goes: if I can do it...Paul, I'm slowly making progress through your wonderful build log. Now on page #159. I have to say your ship's wheel may be one of my favorite elements of your build! Masterfully done, conceptually as well as the execution. Certainly a few quality brackets above the kit's wheel. Speaking of wheels. The wheels inside that big brain of yours must always be turning. Thanks for sharing your thoughts and approach on this important element. Very valuable stuff.
As always, thanks for sharing Paul.Thanks, Marc!Absolutely stunning, Paul. I’m caught up for now, but..
I like the way how you solve the way creating parts (use of the drill) we learning a lot in this log.
Hi Paul,
Nice little jig for milling your octogonal gun pedestals, simple but effective.
Excellent work, Paul.
Very nice technique in the way you milled the hexagonal columns, I've made a bookmark for myself straight away.
Thank you, gentlemen. Very simple once I imagined a way to do it...Oh boy! You are at it again, great work, great techniques. I like your idea to hold and mill those drift rail octagon shapes, effective and clever. I’ll steal that method for future reference if I may?
Cheating indeed! Glorious, marvelous cheating!Milling is cheating…lol…just kidding! Excellent results Paul, it seems you are at home with power tools.![]()
Paul,Hello Friends,
Next up for me was the fabrication of the quarter badge. As I understand it, a quarter badge is sort of like a faux quarter gallery. It lines up with a light (window) and is more decorative than anything else.
Rather than bore you with words, here is a photo essay that shows my solution to this challenging construction:
I'm going to think about adding some decorative bits flanking the quarter badge (carved scrolls or something similar) - but first I want to figure out how the stern is decorated as these should be consistent with one another.
This was a fun little project. I could do it better if I were to make it again because I backed myself into a few corners that led to a few shortcomings - but I'm slowly learning.
Thanks for stopping by!
True storyIncredible and beautiful, Its incredibly beautiful!
My remarks commence with the usual.... OMG this is beautiful!!!Hello Friends,
).……Grant can’tAs the saying goes: if I can do it...
.DittoThanks Paul the magician.
