Assuming arguendo you were unable to source a Byrnes table saw, would you lean toward a Microlux or a Proxxon (or something else entirely, for that matter)? Has anyone had the opportunity to try and compare both?
I have four table saws: 1) A Harbor Freight piece of junk micro-saw, 2) A King-Seely/Craftsman 8" table saw, 3) A 5hp 10" Delta Unisaw cabinet saw, and 4) a Byrnes Model Machines 4" table saw with the micrometer fence adjustment and the sliding table accessory. I can attest that all you say about using a table saw is accurate. To infer, however, that lower priced table saws will make "a proper cut" as conveniently or consistently within tolerances or be as well-built and long-lasting as a Byrnes saw would not be accurate. A Byrnes saw is accurate to .001" right out of the box without fettling or modifications and it will keep within those tolerances reliably. The Byrnes saw will also be much more powerful and capable of cutting the hard woods, metals, and plastics encountered in modeling ships. The only plastic part on a Byrnes saw is the spud for the sawdust vacuum hose. It's up to the buyer to determine whether the "top shelf" price of a Byrnes saw (or other Model Machines product) is justifiable for their purposes. This is sort of like deciding whether the additional money for a Mercedes-Benz instead of a Chevrolet is worth it to you. Everybody's mileage will vary.I learned that to get a proper cut on any table saw you must have: 1) good saw blades. Best ones I use now are not Proxxon. 2) learn table saw cutting techniques; 3) get some experience. All these do not require possession of Byrnes saw.
It is not necessary to do, the saw cuts perfect without. It just takes a little longer to adjust properly. The proxxon and the older fsk/micromark can cut under an angle.purchase something that would require modifications to make it useful.
The housing is plastic, but the saw table and the attachment of the sam, motor and all turning parts are metal. The plastic isn't cheap but strong enough to hold everything. The byrnes is maybe all metal. But the price is to it. When I look to a table saw like Festool, the housing is also plastic.cheap plastic construction and not anything near the quality
This is what I did.Can anyone point to an information source for the mod that appears to be needed for the Porxxon table saw??
micromark.com
By the way. Guys. This micro-mark model looks exactly as Proxxon FET but had a ripping fence with no seeming problems as Proxxon saw has. Fence looks simple and reliable. Does anyone owns this model? Could they share their opinions about this model. If I did not own a Proxxon FET I would probably took a risk buying this saw. Today it is also much less expensive to Proxxon.
Do not forget the Proxxon FET and this model of micro-mark saw they have tilting saw feature which Byrnes do not have.
Yeah, yeah, I know Byrnes has some expensive attachment to do tilted cuts.
MicroLux Mini Tilt Arbor Table Saw | Precision Cutting Tool | Portable
Get precise cuts with the MicroLux Mini Tilt Arbor Table Saw. Its high-torque DC motor and speed control make it ideal for wood, metal, and plastic projects.micromark.com
Thanks, neptune. This fence is "temporarily out of stock" at micro-mark site which normally means forever. Can you clarify? Do you own a Proxxon FET or a Micro-Mark which looks like ProxxoneFet?G'day YT, I had the Proxon Version which is Identical,
