Much appreciated, Mirek!Welcome
Paweł, the workmanship is sensational, I admire it. Greetings Mirek
Working on it right nowWhat a nice composition of cutouts, joints and curved beams in many directions, Paul. Waiting with patience of the results of your ‘breathtakingly challenge’.
Patience, I'm working on a new tutorial.The kit contains plastic (injection molded) carvings including the figurehead. But time has treated them poorly and they are unusable. If I can learn how to carve, I'll be adding handmade ones. My back-up plan is to hire someone to create these for me (3D printed or CNC'd).
Well, it wasn't as difficult as I had feared...Waiting with patience of the results of your ‘breathtakingly challenge’.
Paul is this scrapper custom made or a purchased item. If made, what is the base piece from, assuming the contour is made with a grinding bit.Thanks, Michael. This scraper:
The width of the cheek(s) changes along its length so a normal scraper is hard to use. With this one you can do each side independently.
This are not so good news. I am thinking in the same direction for my sloop. I don’t have any talent for carving. I tried it ones, but this was the horror.The kit contains plastic (injection molded) carvings including the figurehead. But time has treated them poorly and they are unusable. If I can learn how to carve, I'll be adding handmade ones. My back-up plan is to hire someone to create these for me (3D printed or CNC'd).
Again a little beauty in 3 directions, Paul. And that little scraper has recouped its development price twice.Well, it wasn't as difficult as I had feared...
The challenge with the cathead supporter and its associated short rail (eking rail) was that these structures needed to be contoured to follow the curves of the hull both vertically and horizontally - at the same time. The cathead supporter also had to be joined to the eking rail via a scarf joint; but that joint was vertical rather than horizontal and I believe that was easier to accomplish and made the fabrication 'doable' rather than 'breathtakingly difficult.'
During fabrication:
Prior to installation:
And now in place:
The current status of things:
I would estimate that I'm 75% done with the headworks with most of the really difficult parts behind me (not counting the figurehead, that is). Slowly, slowly, catchee monkey...
Hello Paul
It's just one of the shapes of XActo blades (the chisel one). I dulled the cutting edge with sandpaper so I wouldn't cut my finger off handling it, and then used a cutting disc (separating disc) to create the scraping pattern. I did the same thing with a razor blade for the other moldings. I've seen where people soften the metal so they can use files to create the shape (and then reharden afterwards) but I haven't been doing that.Paul is this scrapper custom made or a purchased item. If made, what is the base piece from, assuming the contour is made with a grinding bit.
Thanks for sharing.
Michael
Thanks. The simple fact that I haven't even tried carving yet is why you don't see any decorations on this ship yet. My work table is quite small so when I try carving I'll need to store the model somewhere so I have a place to work...This are not so good news. I am thinking in the same direction for my sloop. I don’t have any talent for carving. I tried it ones, but this was the horror.
Your new knee for the cathaed is looking fantastic.
Thank you, Peter.Again a little beauty in 3 directions, Paul. And that little scraper has recouped its development price twice.
These have been challenging but fun to create. I have to resist the urge to go back and make them again because I suspect I could do them better the second time around - but what fun is that (do-overs...Hello Paul
I like the workmanship of these parts. All those bends, bevels and fitting them together just. KUDOS. You create such a beautiful model
Thank you kindly, Tobias.Outstanding, Paul you really are an artist, everything looks so perfect.
Re-dos are ok till some point after it's better to accept current state is enoughThese have been challenging but fun to create. I have to resist the urge to go back and make them again because I suspect I could do them better the second time around - but what fun is that (do-overs...)?
Thank you, my friend!These small details are what make your model stand out. Again, nice job Doc.
Hi Brad,Do the plans show a metal pole (or rope) from the top of the panel to the top of where the rails meet? I think these were common safety features to give a waist high handhold to sailors working there in rough weather. (see photo below).
Thanks, Dan!Truly amazing!!
