- Aug 28, 2024
Well, as second attempt to made wooden model I start China's kit, America 1851 scale 1:120.
As in such cheap kit I didn't expect any high quality but in this particular, the quality is something "unknown".
Instruction as usual, two sheets of paper without any details or dimensions.
As I learned from this forum, in modeling helps a shipyard, so I made a simple one to assemble ribs, also I made some colors for deck
Before adding deck I made dark brown color for ribs ends, than I glued deck
Is good to made a black background under grid for better look
At this moment I found the small problems, the parts marked at instruction as B and C, have wrong dimensions and bad thickness (should not be made as plywood), same with circle flor part of rudder. Well this is possible for correction somehow but without pleasure of modeling
But there become a real problem with this kit, messed scales, I found after try-on, that the boat frame are much bigger than a hull/deck
, it is so much funny
, as much as disappointing
Anyway, I will try to deal with "this crap" somehow, as I like challenges
, but I warn anyone before buying this kit, it is not a right choose for beginners, even not good for gathering experience.
