Wale and Strake question
Hello all. I’m in the process of scratch building a 17th century Frigate. This is my first time attempting this, so I’m sure I’ll have A LOT more questions.
Today I’m asking about wales and straks. I’m not sure of their exact placement on the hull and how many are supposed to go on. The attached picture is something I found online. The text with it said that straks are thicker then the regular planking and wales are thicker then straks. It appears like there is a strak on the top and bottom of the wale. They seem to be situated in line with the deck, just below where the deck gun ports are. Is this positioning and set up correct? I was under the impression that there should be 2 wales. One under the deck ports and one about an inch below that.
the sheer or curve of the wales don't in most cases follow the sheer of the deck.
you can see this on models where the port is cut into the wale
I see what you’re saying Dave. What determines the sweep of the wale then? Is it just the look that you want it to have? Or does it just follow the curve of the planks in the area that it’s in?
By the way, I’m following your Adventure Galley build log and am building one of my own. That is why I’m asking about the wales.
Wales are set by the master shipwright who designed the ship and drew the plans. Exactly where they go and the sweep is a design element.
Wouldn´t they follow the widest ("thickest") lines of the hull? As they are meant to
a) protect the ship from any collision with an object..
b) stiffen the hull itself
they would be best at the most far "outwards" point of the centerline.
In that case the ships lines do determine the position and the sheer of the wales.
1685504334025-png.377104
What I am very much interested in:
I do understand the interlocking of those wale planks - where the planks have those "hook-like" appearance.
This is perfect for tension stress .. the stress would be transferred from one to the next plank.
But in case of pressure? In that case the beveled longer join between the pair of wales - would lead to a "spreading" of the wales. Why did they do that? What would be a mechanical (or any other?) reason to go for that design?
Anyone an idea?
From Peter Goodwin's The Construction and Fitting of the English Man of War, page 53.
The purpose of these strakes was to stiffen the hull fore and aft in an attempt to overcome the problem of hogging...........they were not laid parallel to the gun deck but to the designed sheer of the ship........top and butt and anchor stock, these being preferred because of their strength and resistance to stress.
You wrote: But in case of pressure? In that case the beveled longer join between the pair of wales - would lead to a "spreading" of the wales. What pressure are you referring to? How would this cause the wales to spread when everything was treenailed in place? You may be right, but if you can explain with pictures or more text that would be super. Regarding the bevel are you speaking about the top edge of upper strake of the wales and lower edge of the bottom strake of the wales. See picture below
Thanks Marcus, your questions and help are very much appreciated
Alan, this an interesting aspect - and thinking about it I begin to understand ..
My "fear" was:
if there is any pressure in longitudinal direction along the wales, the shape of the join partner planks with that angle (red line - in angle vs. longitudinal direction (black centerline) might cause a shear force between the bottom and the top planks of those partners - and that may cause separation of the two partners (orange arrows):
But - thinking about Goodwins explanation I believe:
the impact of hogging on a ships hull is of course a complex thing. We might try to image the effect with a simple "model" - a shoe box.
If you try to bend a shoe box, the side walls will react. They will get stress, tension and pressure - depending on the area you look at - and start to bend in- or outward depending on different parameters and places you look at.
If we imagine a simplified ship hull, we see: the pressure of the water is driving the center of the ship with its maximum buoyancy upwards - while bow and even more the stern will try to sink more deep into the water (if allowed) as the buoyancy of those areas is much lower - although the drop of weight which is not in the same relation.
That means: all joints, all elastic capacity of all used materials (and yes, wood has elastic capacity - especially if it is a very long component as a deck) will "work" under that load.
Your ship starts to bend - and having the joints prepared for this movement increases the robustness vs. that loads.
It makes sense to protect the outer edge on top of our model ship here against tension - as "pressure" will not happen under this load. At least not in longitudinal direction. In theory you would like to have that stiffener as far above the keel as possible - to have a better lever and to increase the geometries modulus of resistance . But in the case of real ships with their complex shape, it may be the level of the wales chosen which may be better - even more since this is the most far layer outside the centerline (in top view).
It is - as always in real life - not that simple. But I think we can trust the shipbuilders of those days. They decided to have those "hooks" to help being robust versus tension. That resolves my fear for stress in the opposite direction (pressure in longitudinal direction) - as that would not really happen in a real ship floating in the water..
The role as "bumper" for the ships side may be an additional function - but I agree to Goodwins perspective.
Primarily it seems:
the wales are mainly there to help keeping the shape under the risk of hogging.
Thanks for pointing on that, Alan !
THANK YOU for your explanation on the forces involved. This is a complex subject but you made it understandable. Thanks again
