Thank you, Geoff! Sometimes I feel like I'm almost done, but when I look at the list I made it feels like I'll never be doneEverything progressing great!
and deadeye chains are absolutely great. You have a very skillful hand for such delicate things.Much appreciated, Adi. I like your detail work as well!and deadeye chains are absolutely great. You have a very skillful hand for such delicate things.
A true jack of all trades!Hello Friends,
Things more important than ship modeling (blasphemy!) have kept me away recently. In recent days, however, I've been able to steal away a few hours here and there to work on the chains.
A photo essay capturing a few of the steps:
This remains a work in progress. The chains associated with the larger deadeyes still need something on the lower end called a preventer plate. About two weeks ago I ordered some dimensional brass strips from a supplier in Germany, and as of today my order is still in Germany. To that end I needed to move on to something else as I await the delivery.
That something else was an anchor.
The kit does include an anchor to be made from boxwood - and I suspect I could have managed to create something presentable out of wood. But I am always aware that I need to develop new skills, so I took a shot at making something from brass.
Here is a drawing from TFFM (Antscherl) showing a 20-cwt anchor (that's 2240 lbs. - just over a ton).
I transferred that image to a 3 mm thick sheet of brass and cut that out using a coping saw (fret saw?):
Since my saw work was pretty lousy (I also burned through about a dozen blades on this lark of a project), I needed to spend the next several hours cleaning this thing up:
After a bit of soldering and some clean-up work:
And that's it for now. My next opportunity at the workbench will take a shot at the anchor stock.
Thanks, Johan. It's true that this hobby pushes us in many directions...A true jack of all trades!
Thank you for your kind words.Hello Paul
Fantastic work, I agree with Jim you should give a try to some scratch build model
Thank you, Roger. It took quite an effort so far...Terrific work Paul, I just love the build and look of that anchor.
Much appreciated, Peter!Your efforts are paying off exceptionally well. Like others above, I would be curious to see what you would lay your hand to for a scratch build, and to follow the progress. Your learning experiences are of benefit to us all.![]()
The smaller the update the greater the reactions…….The smallest of updates... an anchor:
It would seem that I am the only builder on the planet who cannot wrap the ring of an anchor with rope well. I'm now 0 for 2:
Mr. Antscherl (The Fully Framed Model book series) argues that there should be a tapered split between the two halves of the anchor stock for water drainage. Makes perfect sense to me so I did it...
Parting shots:
Thanks for the visit!
