1. Not really. The answer you seek was not arrived at by coarse formulas.Is there a formula for determining ballast?
Yes, there is a general approach to determining the required ballast, but it's not a single universal formula, but a set of calculations. It's based on Archimedes' principle: a vessel must displace a volume of water equal to its weight. Ballast is calculated so that the center of gravity is below the center of buoyancy, ensuring stability. Typically, the vessel's mass (including cargo and equipment) is taken, compared with the estimated draft, and the missing weight is added as ballast, distributing it so that the hull doesn't list or trim.Reading a shipbuilding magazine, I finally found answers to questions that had been plaguing me for years: how to properly distribute ballast, why some hulls maintain stability better than others, and how the slightest miscalculations can change the fate of an entire vessel. There were diagrams, real-life examples, and expert commentary—it felt like I was actually attending a lecture at a maritime academy. It reminded me of how I once searched for a how to contact tv guide magazine and realized that, as in shipbuilding, the right source of information is crucial. In both cases, the key is access to knowledge, and then even complex problems become clear.
That's a good demonstration video, but a professional level planimeter, properly adjusted, is a lot more accurate than he seems to demonstrate. He's using a Chavros brand planimeter. I'm not familiar with their planimeters, but the top end planimiters such as the Keuffel and Esser Paragon models (pictured in the post above) will have adjusting standards (the sort of omega-shaped flat metal pieces pictured) that permit adjustment so that the readings are always spot on. Chavros instruments were primarily marketed as "student instruments," i.e., for college students to buy for use in class. The far more expensive professional level instruments sold in the U.S. by Keuffel and Esser, Dietzgen, and Alteneder, and Richter, Kern, and others in Europe, were highly accurate. (The top end companies often also sold lesser quality lines, as well.) In fact, most quality manual drafting instruments were made by Swiss or German craftsmen in a handful of contract factories and labeled for retail sale by retailers such as Keuffel and Esser or Deitzgen. The good stuff will be made of German silver (a cupronickel alloy, actually) and was hand-fitted with matching serial numbers like a fine firearm. The top end planimeters will also produce readings in many different scales, metric and imperial, inches, feet, acres, etc., etc.
