- Jan 30, 2025
Hiya guys can anyone recommend a masking to use for painting the ships hull
Look for masking liquid.Hiya guys can anyone recommend a masking to use for painting the ships hull
I use Tamiya.Hiya guys can anyone recommend a masking to use for painting the ships hull
I use a sheet of glass.there was a conversation about this a while back. the pointer I picked up is to never lay down a roll of tape on workbench etc. the edge of the tape will pick up fuzz to the detriment of your project.
Check Amazon for model masking tape. You can find widths down to 1mm for making smooth curves and against delicate PE parts as on my model of the USS Yorktown. I mostly use Tamiya 1/2” tape but sometimes back it up with blue painters tape to mask larger areas with the model tape against the model.Hiya guys can anyone recommend a masking to use for painting the ships hull
Also, be gentle with the paint--brush from the tape to the surface you are painting and don't flow it on.Are you looking to make a nice clean line along the hull or just cover up things? If the former, any good painter's tape will work, but it is difficult to edge bend in a nice curve. Automotive pinstriping is good to use for the fine curve then masking tape on top so it lands somewhere on the pinstriping tape. Either way, once the tape is down, seal the edge with a clear coat first. Once dry it will keep the paint that is to follow from bleeding under the tape if the tape is not perfectly sealed to the wood.
Not long ago I bought the 3mm x 18m Vallejo masking tape which, together with the classic masking tape, allowed me to make a "decent" waterline of a plastic German submarine from the Second World War.Hiya guys can anyone recommend a masking to use for painting the ships hull
