- Mar 1, 2022
Thank you for sharing that!I found this online and cannot wait any longer to share it with you, folks!
Hi Waldemar,.
Hi Renato, I'm not sure it actually makes sense to carry out stability calculations for Vasa 1628 as it was actually built. But that is, of course, your choice. The thing is that this ship was ultimately built to proportions that are grossly inconsistent with the practices of the time, as known from contracts, specifications and recommendations of the era, so the results will not be authoritative at all in the sense that they cannot serve as a useful reference to other designs of the period. And the fact that Vasa 1628 was not (laterally) stable is known, after all, even without the relevant calculations.
If I may make a suggestion, I propose to make such calculations for other ships built in the North Continental/Dutch tradition from a slightly later period (because original plans from this somewhat later period have survived). Moreover, for already matured, dedicated warships, as opposed to merchant or rather in a sense experimental vessels like the Vasa 1628. It would be particularly interesting to see the results of such calculations for a frigate by Pierre Chaillé from 1686 or a 72-gun ‘frigate-ship’ from around 1700 (links below).
French heavy frigate of 1686 – designing a ship in the Dutch manner
. This plan of a heavy frigate, drawn up by the French shipwright P. Chaillé in 1686, is a real gem. First of all, until now it was virtually unknown what conceptual methods were used on the Atlantic coast of France (Ponant) until the very last years of the 17th century, that is, until the...shipsofscale.com
The Dutch 72-gun ship ca. 1690 – the apogee of Dutch ship design of the Classical Age
. It should be clarified at once that this plan, tentatively dated by me to the end of the 17th century, is one of the last of the era before the widespread adoption of design diagonals, which in the Netherlands occurred in the third decade of the 18th century at the latest (see as to this Ab...shipsofscale.com
There is a specific reason to verify the lateral rigidity of truly dedicated warships built à la hollandaise. Well, in many period paintings by considered to be the most meticulous artist-painters such as van de Veldes, these warships are often so deeply immersed in the water that the gun ports appear to be above the surface no more than about the height of the gun ports, i.e. only, say, in the range of about 2.5–3 feet, sometimes perhaps even less. Was this because the Dutch-designed warships of this period were particularly laterally rigid, despite the fact that the hull forms of these already dedicated warships were actually quite sharp and do not seem to have any particularly large reserve of underwater volume to reinforce lateral rigidity, as is the case with merchant ships? Or perhaps is it more the effect of artistic license?
Besides, although a 3D scan of the Vasa 1628 has been admittedly made, it is highly unlikely that you will get anything of the sort, as there is a strong general tendency or custom among the professional researchers and archaeologists involved to keep the collected data or preserved artefacts for their exclusive use, at least so long until a relevant publication is made to their credit. For example, research-worthy contemporary ship models, critical graphic documentation produced during the excavations or 3D scans may be kept in semi-private offices or computers for many years under the pretext of being studied, with accompanying declarations of intent to publish their results in the more or less distant future, but the net outcome is that direct access to these data is usually denied or at least very difficult to anyone else. I have personally come across a number of such cases.
Back to the point. On the left you can see one of the many examples of the very short distance of the gun ports from the water (Gouden Leeuw by Willem van de Velde), and on the right the inclination of the ship, which would clearly put such extremely low gun ports under water (Hollandia by Ludolf Bakhuizen). Don't you want to investigate this very phenomenon?
Regarding the question you asked, I should actually take a closer look at the characteristics of the ships you showed me, but I wouldn't be surprised to see poor stability even for these. In order to ensure a certain resistance to heeling, in fact, it is necessary that the weight of the ship is distributed low down as much as possible, in addition to having a large waterline and a large reserve of thrust. Therefore, compared to a merchant ship, for a warship of the type mentioned above I would generally expect both worse stability and worse buoyancy. I hope I have been exhaustive!
heres a thought, in the olden days of the 1990s, it was said that the ships of the mediterranean, and of most of europe were designed on teh basis of rule of thumb... width is this much of length, and so on..
In china, the junks have always been designed by proportions.. so if they find an abandoned rudder post or rudder on the river bank, they can measure it and tell you how long the junk was.
Ive seen the articles years ago, how chinese experts have dredged up a piece of ships rudder and been able to give a complete blueprint of the junk or sampan by using the 2,000 year old "rules of thumb" used to build junks and sampans in that time..
Why not take a look at the sources on this matter (as indeed on others). Here is a fairly typical account of this issue from the period (Georges Fournier, Hydrographie, 1667, p. 21):
To be honest, I personally know an even better magician, incidentally a historian by education and employee of the maritime museum. He claims that one can faithfully reconstruct an entire vessel solely on the basis of a short piece of ship's keel found.
I am glad that people enjoy these videos, they were great fun to make!
Fred
Do you have any basic pictures of these sweeps for the benefit of those new to ship design? It is difficult to envision the role of these curves and their position on a draught with when one has no understanding of the terminology, i.e. sweep, master frame, breadth sweep, etc..
For the benefit of scholars and the academic world of maritime archaeology and shipbuilding history in general, the current state of knowledge regarding design concepts in the early modern period, based on the author's latest research, can be summarised as follows (for the underwater part of hulls):
Southern or Mediterranean tradition — geometric construction of the master frame consisting of three sweeps of constant radius (sometimes more, which is not particularly significant for the essence of this method); one fixed master frame template transformed (moved and rotated) over the ‘entire’ length of the hull, or at least between the quarter frames, and guided by the line of the floor and the so-called ‘bocca’ line, the latter coinciding with or parallel to the deck line; geometric elements of the hull bottom, connecting the hull body proper with the keel assembly, defined at the end of the design process.
It is also necessary to mention separately the variant featuring a breadth sweep of variable radius, which I intend to demonstrate in detail when discussing the work of Robert Dudley (both its published and unpublished part), created in the first half of the 17th century.
Northern tradition — geometric construction of master frame normally consisting of two main sweeps of variable radii (except in the simplest cases or sporting additional reconciling sweeps of an auxiliary nature); the hull bottom, guided by the line of the floor, is defined first; breadth sweeps guided by the line of greatest breadth (as opposed to the ‘bocca’ line in the Southern tradition); bilge sweeps, connecting the hull bottom with the breadth sweeps, defined at the end of the design process.
Ships in the Northern tradition could be built employing both the ‘skeleton-first’ and ‘shell-first’ techniques, however, these techniques are purely carpentry-related and do not replace proper design. In other words, both of these carpentry assembly methods are merely the practical implementation of properly understood designs.
English tradition (developed around the second quarter of the 17th century) — is, in a sense, a synthesis of the two previous methods or a derivative of the Mediterranean design method, depending on which evaluation criteria are considered more important. The geometric structure of the master frame typically consists of three main sweeps, which may be of fixed or variable radius (this applies to all these three sweeps), and now guided by the rising and narrowing lines taken from the Northern tradition (i.e. the line of the floor and the line of greatest breadth); the general design sequence is as in the Mediterranean tradition, i.e. the geometric elements of the hull bottom, connecting the hull body proper with the keel assembly, are defined at the end of the design process.
Thank you,
Waldemar Gurgul
