I agree with Corsair, A great source of light and optivisors are invaluable.
Rob
Rob
Brilliant (no pun intended) idea!For me with a beginning cataract the key word is light. This is the (partly) solution for me for less than 50 euros a combination of an aluminum strip (40 x 4 mm) screwed to the sides of my table and a strip of high quality white led light.
Impossible to work without it, even in broad daylight.
(Don't look at the mess on my table. I did clean up last month.)
View attachment 503433View attachment 503434View attachment 503435
IF your doctor suggests cataract surgery may help, you might be able to select from a range of replacement lenses. For example choosing a focal point of, say, 18 inches might allow you to build models without glasses but you'd need glasses to driveI had cataract surgery done a couple years ago for seeing far. I have a 40 watt led light above me and I went on Amazon and purchased a couple different pair of magnifying eye glasses. For $20 you get 2 pair. I got a 3.50 and 4.00 for up close work and they've been great. They fold up and fit in a neat little holder they come in.
I've tried a few different types and found these to be the best ones as well. The others give me head aches! I stuck a head torch on mine which is really great for lighting the area where you are working as it is pointing right where you look, the only thing you have to watch is that the visor does stick out a fair way and it is easy to forget and bump into the rigging work.I use LOTS of lighting and an Optivisor View attachment 503225 You can get them at a decent price from Amazon.
The good thing about these rather than a single magnifier lens is that with these, you still have depth perception. You can also get different magnification on them.
I remember Erik Ronnberg saying years ago about vision, "You'll notice a difference" Indeed I have. I surrendered to magnification about 15 years ago and now am amazed on how much I depend on it, and the quality of what I used to do before without it. There are, of course, the desk lamps, and Robin Neill introduced me to the inexpensive reading glasses I often just pop over my regular glasses when necessary.Hi.
Getting older now and the old eyes struggle a bit more each day.
How do you other oldies like me adapt and soldier on ?
So frustrating at times. Do you just grin and bear it ?
One bright spot - not being able to see fine detail as well, I really don't mind unfortunate workmanship as much as I used to. With this, I take a visual pleasure in what I can manage as I trail off into my dotage.
Ships in bottles save room and are much easier to keep clean. The "save room" is important if you're married.I had pretty much resigned myself to the fact that the older I get, the larger scale I would have to work in. You seem to be going the opposite direction.![]()
