PLEASE MAYBE ADINISTRTOR OR MODERATOR CAN SOMEONE GIVE ME A LINK I WOOD LIKE TO PURCHASE THIS ONE PLEASE HELP GOD BLESS STAY SAFE ALL DON
Hi. Before I bought my Proxxon lathe I tapered masts, booms and gaffs just with a electric drill with variable speed.Can anybody recommend a method for tapering masts, booms and gaffs without using a lathe? I don't think the masts and so forth on my Hoogaar need much tapering but some of course.
Thanks Peter, that sounds like a good idea!Hi. Before I bought my Proxxon lathe I tapered masts, booms and gaffs just with a electric drill with variable speed.
Clamp the drill on your workbench, guide the end of the round with one hand and tapper it with some sandpaper in you other hand. Just slow and relaxed, take your time, don’t push to hard.
Hello Don,CAN SOMEONE GIVE ME A LINK I WOOD LIKE TO PURCHASE THIS ONE
Hi! Thanks for explaining this!... sorry for popping onto your build report out of nowhere - but it is permitted to post retail webpages
As I started the block plane question I feel I should chip in.Yes, that certainly is a better method however I can't find where to buy a good block plane here plus I lack the proper saw for rip sawing thin wood with a taper. My table saw is too big for that and not fine enough for small things. Maybe I'll eventually buy the 'Proxxon'' mini table saw which I looked at today. It would be great for thin stuff like strip wood.
But not having a plane I plan to use my 'Einhell' Disc/Belt sander and also my 'Einhell' Delta sander. If my results are poor I can always go back for some square stock.
Here's my sander it has 80 abrasive.
Greetings! UrkVisser
One vendor where you can be sure of getting a good plane is Lee Valley. For any brand you'll also need a method for keeping it sharpened.Thanks Jim!
I'll build what you have shown here. Hopefully I can find a good sharp plane here.
Best Regards, Urk Visser
Thanks for the tip Van!One vendor where you can be sure of getting a good plane is Lee Valley. For any brand you'll also need a method for keeping it sharpened.
All you need is a little finger plane. The first picture is my Stanley #101. No longer made but they are available used. The second is a Jorgensen 3.5 inch mini plane, which is available on Amazon for $14.98. Fair winds!Alas, Lee Valley won't deal with me here in Germany in Euros but these Canadian 'Veritas' planes look wonderful! I just discovered a 'Veritas' dealer in Berlin who has several models of 'Veritas' mini planes for between 75 and 100 € or so (even in a gift box). I'll definately consider buying one!
Here is also an interesting type of plane called a 'Spoke Shave' which is designed for planing round stock such as wooden wagen wheel spokes and costs under 30 € in the Netherlands.
Hi Ab!Hi UrkVisser,
Compliments for your builds.
Has nobody in Holland so far taken the trouble of telling you that the ship type you are building is in fact called a Hoogaars with an s on the end? I suppose you thought that the s was for the plural form, but the name is really Hoogaars (singular). It means something like 'high butt'. Not very elegant, but nobody is to blame for that.
Good luck with your build.
Ab
Thanks for the info!Having had a better look into my book case I found out that there are two versions of the book. I have them both for some reason. Apart from the simple one I showed earlier, there is also a more luxurious edition with lots of new details, like for instance the stove. I copy the pages here:
It turns out that Hoogaarzen (plural) also fished on shrimp. And these poor creatures were cooked alive straight out of the net.
Here is the info I found:
View attachment 504769View attachment 504770View attachment 504771View attachment 504772
Hope this helps.
Ab
