Primer or none
The hull is sanded, ready for paint and masking tape placed.
When watching online builds some of the builders use primer. Most don't.
I will be using Mission Models Ochre and Tamiya Flat Black. Should I primer firs17438153600445630285535995618113.jpgt
I use acrylic paints for painting ships hull. I do not use primers. Primer would mar the wood texture I want to show on the model. I use diluted paint and apply many layers till I am satisfied with looks. This is how I do it. You should do what ever you like.
I concur with the previous replies. I sometimes prime, sometimes not. It depends on the colour and absorbency of the wood, the colour of the paint, the opacity of the particular type of paint, am I spraying or brushing, how good was my finishing of the model...
I suggest experimenting, ideally on a test piece finished in the same way as the model, or on a small area down by the keel, and seeing what works best for you.
Thanks, I want the wood grain to show. I did a test without the primer and it looks good. I was concerned about durability but no one mentioned that.
I have been using sanding sealer first. I find that paint can "raise the grain" of the wood and, at least in my hands, a coat of sanding sealer makes the finished product look better. The wood grain still shows with using it.
Rob
Thanks
Here's the results after using a second coat of Model Expo Yellow ochre hull paint. I'm happy with it.IMG20250405082447.jpg
