Hello everybody.
I want to share my first project here with you. I planned it when the huge RMS Titanic was first time mentioned from Trumpeter as 1:200 scale model, started to collect lot of add on parts since that and finally started to work on it a few weeks ago. What am I planning here.... or what upgrade stuff will be used ... ?
I started with the stern plating ...
And continued with the under hull plating made of lot of plastic parts ...
The new rudder and the propeller hoses made of 3D print:
I corrected the hull plating at the center of the propellers at the stern as well ...
... and applied first photo etched parts on the hull ...
... corrected the complete hawse pipe at the bow ...
... so far for the moment. That's the actual situation on my built.... some further work necessary on the hull ....
Next step - finishing the hawse pipe, stern plating and the hull plating, which still need some further sanding and corrections / works ... then the hull support with the first electric issues ...
I hope you like it so far ...
Cheers
Michael
- KA Models DX Detail set with wooden deck
- Several 3D printed parts from Andews 3D and Artie 3D models
- Several photo etched sets from Woodies Model Works
- Under hull plating from Woodies Model Works
- Stern plating from Minibrass
- Hull support set, lighted masts, super structure from Andews 3D
- light and sound kit from MSM
- 3D printed parts from YZM
- different further stuff ... more details later ....
Cheers
Michael
