Product Review Spin Wars: Annie's JF-108 vs. JimDoa'a JMD-109S in the Hobbyist Arena
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
When it comes to precision work in our hobby—whether you're shaping wood, cleaning up tight corners, or polishing small parts—a good rotary tool can make all the difference. While traditionally marketed as nail drills, compact devices like Annie's JF-108 and JimDoa's JMD-109S have found their way onto hobby benches for their fine control and versatility. In this review, I’ll compare these two budget-friendly tools from a modeler’s perspective—focusing on their performance, comfort, and practicality for shipbuilding and other miniature work.
Just to be clear—I bought both of these tools out of my own pocket, and no one’s tossing doubloons my way to say nice things. This isn’t a sponsored review, just my honest take from time spent actually using them. So if I like something, it’s because it worked for me. If I don’t—well, I’ll let the chips (or wood shavings) fall where they may.
Before landing on these two tools, I tried out the Yoke Fellow portable nail drill, but it quickly sent me back to the drawing board. The main issue wasn’t the cord running to the battery pack—that was manageable. What really drove me nuts was the clumsy control system. It relied on a single large button to cycle through speeds, and the way it operated just didn’t offer the precision or ease I needed. You had to fumble through speed settings rather than dialing in exactly what you wanted, which made it frustrating for detailed hobby work. That awkward interface was the real dealbreaker—and the reason I started looking for a better tool in the first place.
Let’s start with the Nail Master JMD-109S by JimDOA. What first drew me to it was the slick, modern design—it just looked well thought out and clean. But what really impressed me once I got it in hand was the charging base, which turned out to be magnetic. That was a pleasant surprise and a welcome one at that. Anyone who's used rotary tools knows the struggle of trying to keep them from rolling off the bench like they've got a mind of their own. The magnetic stand, which also doubles as the charging base, keeps the tool upright and securely in place. It’s a simple feature, but incredibly practical for a hobbyist's workspace. The charging stand also has a handy feature—a set of holes to hold up to 6 bits. While 6 might not be a huge number, it’s a nice touch that helps keep your essential bits organized and within easy reach. It’s small conveniences like this that make a difference in a well-designed tool.
The packaging of the Nail Master JMD-109S also deserves a mention. It reminded me of unboxing an iPhone—solid, hard cardboard with a premium feel to it. Inside, the tool is nestled securely in a molded plastic tray, which keeps everything in place and protects it from any potential bumps or damage during shipping. It’s clear that a lot of thought went into the packaging, ensuring the tool arrives in perfect condition and giving you that “premium” unboxing experience right from the start.
Technical Data:
Model: JMD-109S
Type: Electric Mini Nail Drill Rechargeable
Material: ABS+Aluminum alloy
Speed: 0-35000RPM
Rotary Direction: Foward/Reverse
Power:15W
Output Voltage: DC2-5V
Input Voltage: AC 100V-240V 50/60HZ
Color: Red, Gray, Purple
Weight: 0.6kg
Size matter! One thing I didn’t quite expect was the size of the tool. From the images, I had pictured it being a bit smaller, but it does come across as a little bulkier in person. Of course, that’s purely on me for not checking the size chart beforehand. It’s still manageable, but if you’re expecting something ultra-compact, it might feel a bit more substantial than anticipated.
Operation Controls:
While the slightly larger size than expected was manageable, the real disappointment came with the touch-button operation controls. I can’t tell you how many times the speed accidentally increased or decreased on its own due to the slightest touch of my hand. It’s incredibly frustrating because when you’re focused on your work, the last thing you want is for the tool to suddenly start spinning faster or, worse, slow down just when you need it. The lack of tactile feedback and the sensitivity of the buttons make it difficult to hold the tool properly without unintended adjustments to the speed.
To start the tool, you have to press and hold the ON/OFF button. It always powers on at speed 00, which means you then have to tap the arrows on the screen to set your desired speed. Here’s the kicker—when you stop to change the bit and restart the tool, it resets to speed 00 again. Seriously? It’s such a basic design flaw, and it can be really frustrating when you’re in the middle of a task, only to have to reset the speed every time you power it back on.
Another annoying issue is that lightly touching the ON/OFF switch can change the rotating direction. The problem is, you don’t need to stop the tool to switch directions, so you might be working on something, focused, and then boom—the tool starts spinning in the opposite direction. It’s not only frustrating but can also be risky, especially when working on delicate details or near your fingers. One wrong touch, and you could end up damaging the work or even yourself.
So, is there anything good about this tool? Yes, definitely! While the touch controls aren’t ideal for me, the tool itself is solid in many other areas. It features a 2.35 mm collet chuck with a precise mechanism, making it great for holding bits securely. The tool is surprisingly quiet for its power and offers a decent amount of torque. I used a 0.5 mm drill bit at various speeds, and I got excellent results—smooth, consistent drilling without any wobble. Plus, it has an auto power-off feature, which is a nice touch—it helps preserve battery life by shutting down automatically after a period of inactivity. As for battery life, I haven’t had the chance to run it for hours on end, but after using it for about an hour, I noticed it dropped just one bar on the battery indicator (out of four). It’s clear that the engineering and build quality are top-notch, even if the controls leave something to be desired.
Conclusion:
The JMD-109S stood out for its sleek, modern design, and what initially caught the magnetic charging base. This base not only keeps the tool secure while charging but doubles as a stand, helping to organize bits with space for up to six. While the tool’s slightly larger size than I expected wasn’t a dealbreaker, the touch-button controls were. Unfortunately, the touch-sensitive control buttons often led to accidental changes in speed and rotation direction, which was frustrating when I needed consistent control. Every time I stopped to change a bit, the tool would reset to speed 00, requiring me to reset the speed—another design flaw.
That said, the JMD-109S is not without merit. It features a 2.35 mm collet chuck for precision and a solid build, making it surprisingly quiet with good torque. I tested it with a 0.5 mm drill bit at various speeds and got excellent results. It also has an auto power-off feature that helps preserve battery life, though I didn’t have the chance to test it for a prolonged period. After about an hour of use, I noticed the battery dropped one bar (out of four), indicating decent longevity.
Overall, while there are some notable frustrations with the controls, the JMD-109S shows strong performance in terms of precision, quiet operation, and battery efficiency. It’s a solid choice for hobbyists, as long as you can work around the less-than-ideal touch-control interface.
Annie’s JF-108 offers an appealing blend of functionality, design, and affordability. It has a clean and sleek design that immediately stands out. Its compact size and modern look make it feel like a stylish addition to your workspace. The packaging is sturdy and well-organized, with the drill and accessories safely stored in molded plastic to prevent any damage during shipping. It’s not as flashy ;) as JMD-109S but it definitely feels like a tool that knows its purpose—simple and effective.
Unlike the JMD-109S, the JF-108 is noticeably smaller and shorter, with a sturdy aluminum alloy body that feels solid and well-balanced in the hand. That compact size plays a big role during long sessions—where the longer, bulkier JMD can start to feel like you’re wrangling a hoer, the JF-108 stays nimble and easy to handle. It’s less tiring on the hand, especially when you're deep into detail work and already leaning over your bench like a shipwright with a deadline.
This tool features a straightforward control system that’s easy to get the hang of—even for beginners. No touch buttons here! Just press the ON/OFF switch, and the tool starts spinning right away. Speed is adjusted using a dial, giving you smooth and precise control from low to high. Need to reverse the rotation? Just press the dial, and you’re good to go. The digital display shows both the speed and the direction, so you always know exactly what’s going on.
When it’s time to change the bit, you’ll need to stop the tool by pressing the ON/OFF switch—but here’s the good news: when you power it back on, it picks up right where you left off, keeping your last speed setting. No more resetting your dial every time you pause. It also features an automatic shutdown function to help preserve the life of a high-performance battery, which is a nice bonus when you forget to turn it off mid-project (hey, we’ve all been there). It seems that 2.35mm is the standard shaft size for most nail bits—and conveniently, it’s the same for many jewelry tools too. Both the JMD-109S and the JF-108 use collet systems with clasp-locking mechanisms located inside the body. In my experience, this setup does the job just fine—the bits stay firmly in place, with no wobble or slip during use.
Charging the JF-108 is straightforward. It uses a USB-C connection (cable included) which is always a plus in my book—no hunting for some weird proprietary cable. The charging port is located on the side of the handpiece (the first time seen such a setup), but takes about 40 minutes for a full charge compared to 20 minutes for JMD-109S.
As for battery life, while I haven’t pushed it to the absolute limit, it’s holding up impressively so far. I’ve used it for a few sessions—around an hour each—and the battery barely budged. It seems to sip power rather than guzzle it, which is great if you're planning longer hobby sessions without being tethered to a charger. Until I do a full drain test, I’d say the battery life feels solid for its size and purpose.
Conclusion:
The JF-108 may not have the sleek, futuristic look of the JMD-109S, but it more than makes up for it with practical advantages. Its control system—reliable physical buttons and a smooth-turning dial for speed control—is far more intuitive and user-friendly compared to the overly sensitive touch controls on the JMD. While its design isn’t quite as slick, the JF-108 delivers where it truly counts: it’s smaller, lighter, and feels more natural in the hand during long sessions. It offers precise performance through a solid collet locking mechanism and holds power impressively well. And one of its biggest wins for both tools? Complete freedom from wires—no more getting caught up or restricted while working. In my personal experience, for hobbyists looking for a dependable, compact, and efficient rotary tool, the JF-108 makes a strong impression and has definitely earned its spot on my bench.
Thanks for reading! I hope this comparison and my personal impressions of the JF-108 and JMD-109S help someone out there who's hunting for the right tool for their hobby setup. If you’ve used either of these—or a similar tool—I’d love to hear your thoughts and experiences. Got a favorite? Had a different outcome? Drop a reply below! And of course, if you have any questions about these tools or want to chat more about rotary setups, feel free to ask—happy to help!
Appreciate everyone who stops by to read and share.
Jimsky
Ai ai, now I want one.
Good review. Thanks
That’s awesome to hear you’re thinking about getting one! Out of curiosity—do you find yourself leaning more toward the JF-108 or the JMD-109S? I’d love to know which one caught your eye most and what features matter most to you. Always fun to hear what others prioritize in a tool!
The 108, because the issues of the 109 with the controls are serious when you use it for fine work like I do.
I looked these drills up on Aliexpress and you have too look carefull if the one you buy doesn't have a poor battery inside. There is difference in mAh. That's probably the difference in power performance. A battery with a lower mAh will have also a lower peak performance.
I don't now if you can change the powerunit. Probably there is a 18650 battery inside. If that's the fact, then it's good news, you always change them.
Technical Data:
Model: JMD-109S
Speed: 0-35000RPM
Power:15W
Weight: 0.6kg
Operation Controls:
Conclusion:
Conclusion:
Jimsky
Another good review and presentation....purchased from?
the jf108 looks to be my choice. im not a fan of those press control buttons. start at the last setting is nice and the dial speed control is a selling point id consider important.
but of course to have it in hand would determine the final pick. id be interested in the torque of these machines. i like to have some guts when hogging out a chunk of wood or trimming n drilling brass.
next time i visit the mall, ill stop in the nail joint to see what they are using n get some insight what they consider important.
Thank you! I bought the JMD-109S from AliExpress and the JF108 from Shein, which, like AliExpress and Temu, is a Chinese online marketplace. I benefited from an excellent introductory offer as a new Shein member.
While these tools are primarily for nails, it's important to understand that their torque characteristics will differ from dedicated woodworking tools. Furthermore, the torque capabilities vary considerably even among tools designed for nails. Both machines in this review offer a satisfactory level of torque for processing wood at higher speeds, although the material's density will be a determining factor. I am considering creating short videos to demonstrate their wood-processing performance.
I put together a few short videos to demonstrate the torque of both rotary tools featured in my review. The first one I show is my personal favorite—the JF108. I also wanted to give a sense of its size in relation to my hands, and offer a quick look at how it performs.
To start, I used a coarse bit at a low speed to remove some wood. It worked, though I noticed that if I pushed too hard, the tool would slow down. Increasing the speed made shaping the stock much easier. Once I cranked it up to maximum—or close to it—the work became effortless.
Next, I switch to a sanding drum, again using a coarse grit to demonstrate how much material you can remove at different speeds. And finally, I tested drilling with a 0.5 mm bit. As expected, the higher the speed, the quicker and cleaner the hole. For all of these tests, I used pearwood as the material.
In the next video clip, I put the JMD109S through the same tests to get a sense of how it stacks up. While the tool gets the job done, the experience isn’t quite as smooth. The touch control, in particular, makes precision work feel a bit clumsy, especially when you're trying to replace the bits and adjust the speed.
I ran it through the usual steps: shaping wood at various speeds, sanding with a coarse drum, and finally, drilling with a 0.5 mm bit. Performance-wise, it holds up, but there’s a slight lack of finesse. The torque is there; it is a slightly bigger size, but the sensitivity of the controls can make consistent handling a bit tricky, especially during delicate tasks.
Again, the material used here is pearwood, and while the results are acceptable, I found myself missing the more intuitive handling of the other tool.
In conclusion, both tools are capable of handling typical ship modeling tasks—carving fine details, shaping bulkheads, sanding contours, and drilling precision holes. The JF108 offers smoother control, making it a better fit for delicate shaping and controlled carving. Its responsiveness at different speeds gives you confidence when working with harder woods like pear.
The JMD109S, while it has the power for the same jobs, feels less refined due to its touch-sensitive controls. That can make it harder to maintain consistent pressure or speed, especially during precise drilling or when you’re trying to gently shape a curve. It’s usable, but not as intuitive.
For modelers who value feel and finesse in tight workspaces, the JF108 clearly has the edge.
Just out of curiosity, will these nail drills handle the same shaft sizes as are used by Dremel tools? I bought a Coslus nail drill which works off of a USB power supply (It is not cordless). The body is much smaller but it can not handle the shafts of Dremel size bits. The machine is wonderful for sanding and shaping and seems to have as much torque as you demonstrated on your video. It is priced at $9.99 and come with 6 different heads and a sanding drum head with a lot of different grit sanding drums. Here is the buying information
Rob
Rob
Hi, Rob.
Good question! No, neither JF108 nor JMD109S nail drills don’t take the same shaft size as standard Dremel bits—Dremel uses a 1/8" (3.175mm) shank, while mine both tools are designed for the smaller 3/32" (2.35mm) bits typical of nail drills. So unfortunately, Dremel bits won’t fit.
However, I know, and @Steef66 can probably confirm, that some nail drill handpieces can be fitted with collet chucks that accept 3.00mm and even 3.175mm shafts. I’m fairly certain that spare chucks are available for both of my machines as a replacement if one wears out, but I’m not sure if they make chucks specifically sized for additional shaft diameters, like the 3.0mm and 3.175mm used by Dremel.
Here is the link so you get an idea
Hi, Rob.
Thank you for your review Jim!
one thing for sure... the price is right! the 108 is really nice and seems like a good preformer, especially with the speed dial feature. i noticed how small it is in your hand... i like that.
thanks for the reviews n videos.
Thank you for the reply. I've never used Shein but have now checked it out. It says the JF108 is sold out :rolleyes:
I seen more then 10 sellers on Aliexpress who sell it, just keep looking for a fair price and seller.
Yeah, AliExpress and Temu have this product; it might have different names associated with it. By the way, they come in different colors as well.
