Fram by Occre
UK Dorset
Why the Fram?
Having just completed the Royal Caroline (very ornate) and Cutty Sark (25 sails) I fancied something a bit simpler as a summertime activity. A leisurely complement to a beer and a pipe on the patio watching the lawn grow. It is not a very pretty model but my main enjoyment of our hobby is the building, not the subsequent display. It is a satisfying way of using (and acquiring!) tools and working with wood to replace the more robust DIY of my younger days.
The Fram has a hull shape and deck fittings that are distinctly different from my earlier builds: no forecastle, quarter deck and poop, no cannon. Instead, a funnel, ventilation pies and a propeller. The rig is predominantly fore-and-aft which is a novelty for me and will eventually require a shelf of modest width.
Unboxing.
With several OcCre models already built I found few surprises. The usual compartmented box of bits, a set of pre-sewn sails, rigging threads, 2x5mm lime planking, 0.4x5mm (paper thin!) sapele and a bundle of dowels in a close grained white wood. With occasional exceptions I find the OcCre instructions clear and comprehensive. There are plenty of coloured pictures of an actual build. A pdf is also available for download which is often a convenient supplement to the paper version.
That sounds like a perfect summertime project, and I’ll be following your build log with great interest! The Fram’s design really stands out with its unique hull shape, fittings, and rig, especially compared to the more ornate and traditional ships like Royal Caroline or the Cutty Sark. I also really appreciate your philosophy, focusing on the joy of building itself rather than the final display. There's something especially satisfying in working with wood, tools in hand, with a pipe and a cold beer nearby. I’m also a pipe smoker and a fan of a good beer, so your description of building on the patio while watching the lawn grow hit home for me!
By the way, I just recently posted a kit review of the Fram over on SOS. If you haven't seen it yet, feel free to check it out and let me know what you think!
I have just re-visited your excellent kit review (I did read it some time ago) and found it very helpful and thorough. I should have referenced it rather than writing my relatively sketchy unboxing post.
I have a minor issue with your recent post: by all means chill your lager but beer should be served at no lower than cellar temperature!
Some years back I was with a party of Brits attending a conference in Arlington, Texas. We were delighted to find an "English Pub" selling excellent Sam Adams draught beer. However, it was served in thick, pint glasses taken from the freezer. On our second (of many more) rounds we declined fresh glasses and asked for our original glasses to be refilled. "We've got these warmed up"
Addendum: your coffee is great but your hot tea is not treated with sufficient respect - even when you are not dumping it in Boston harbour.
Thanks so much for revisiting my kit review. I'm happy you found it helpful! And don’t worry at all about your unboxing post; it was a great read. Sometimes a sketch says more than a blueprint, especially when it comes with personality.
Now, about the beer… fair point! I’ll admit to chilling my lager just a bit below “cellar poetry” level—but only because my shipyard tends to overheat faster than a cannon in a broadside. ROTF I promise to leave the proper beer temperature debates to the true connoisseurs—and next round, I’ll try to drink it before the glass frosts over.
As for the tea—ouch, that Boston jab still stings! I assure you, no tea has been harmed in the making of this build (well… maybe slightly bruised). I'll steep one properly in your honor next time. :D
I can’t say you’re wrong about the tea, but you’ll have to make some allowances for our treatment of fermented grain. It’s only been in the last few decades that Americans have rediscovered how to make good beer. We’ve been making do with the stuff coming out of Milwaukee and St Louis for so long, the only way we knew how to drink it was so cold you can’t taste it. ROTF
Preliminary Analysis.
The first photo below shows the laser cut boards marked up to measure and record the stem and bulkhead profiles. These data are fed into a noddy computer program to get a preliminary idea of how the planks will behave when fitted on the hull.
In the second photo the planks are initially fitted with the full 5mm width on the widest bulkhead. The upper part of the picture shows how the planks would need to be individually shaped as they bent round the bulkheads and allowed to follow their natural line with no lateral bending. The lower part shows how the seams would look on the hull. The black line approximates the stem; the red line shows the profile of the widest bulkhead. The plank widths are marked and vary erratically. The bow is the main point of interest. The program struggles with the stern as the planks pass under the counter.
The third picture shows haw the planks would fit if they were all tapered from full width at the fattest bulkhead to 70% of the width at the stem. A small amount of lateral bending would be needed to fit them together.
These results suggest that planking the Fram should be relatively easy.
In contrast, the last photo shows the results for the bluff bowed Revenge. Even with severe tapering to 40% at the stem there would need to be a lot of lateral bending.
These results are very approximate. Refinement will come when the planking is being fitted to the hull.
I'm building the Fram right now. I'm modifying the project to look more like the Fram on display in Oslo. Which is to say rougher and without the brass everything OcCre provides. Also, study the picture of the finished ship on instruction sheet "T". You'll get a kick out of the boom and sail locations midship. I will be modifying those as well. It's been fun so far.
Initial steps
Build strategy
I am resolved on this build not to get bogged down with long sessions of single, repetitive tasks. In the early stages of build there are many tasks that can be carried out in parallel rather than in series: planking the hull, shaping and finishing the spars, assembling and painting deck fittings, sewing bolt ropes on sails, stropping blocks, assembling cannon (if relevant) and preparing deck planks. I have made this resolution before but it always seems to get trumped by an urge to finish one job before starting another. This is commendable in some activities but not necessary in ship building. Perhaps it is connected with the supposed inability of us chaps to multi-task, The main disadvantage of this plan is having to keep planking tools, rigging tools, paints and brushes concurrently active in a limited workspace. I wonder what strategy other members adopt.
After extracting the bulkheads from the pre-cut sheet, I have cleaned up the charred edges and put a tentative chamfer on the bulkheads near stem and stern. A dry fit on the false keel revealed very poor fitting. The slots in the mdf keel would be a snug fit for 4mm plywood bulkheads; Unfortunately, they are 3.8mm thick – not up to the usual OcCre standards. A picture below shows the initial fit. The decks have been temporarily fitted to square the bulkheads. A screw holds them into their ultimately curved shape. One doesn’t get much bite screwing into the edge of mdf; I was almost inclined to cut a plywood replacement – with slots appropriate to the bulkhead thickness. But I couldn’t be bothered so I added some blocks into the bulkhead/keel corners.
Deck planks
The plan sheets include the generic OcCre instructions for planking the decks: lay full length planks then mark off the joints with a pencil line and the fixings with pencil dots. I have done this in some of my earlier builds and it looks passable but I think I have grown beyond of that.
So, how were the deck planks fixed on the Fram? I’m sure that by 1893 the use of trenails had ceased so what to do instead. Some mages of the real Fram show the upper decks but the details are hidden by a layer of something looking like black paint. I don’t know if this is something authentic or whether it has been put there to provide secure footing for the visitors or to preserve the planks. I don’t think I will paint the decks black on my model.
A failed experiment.
I Clamped together a stack of deck planks then drilled small holes (0.7mm and 1.0mm) where the fixings would go. I then passed some PVA soaked rigging thread through the holes. When the glue had set, I separated the planks in the bundle with a thin blade hoping that the short lengths of thread would stay in the holes. They didn’t! It might have worked with thicker planks but not with the usual thin ones.
Next attempt.
I smeared wood filler on the under side of the test planks and forced it though the drilled holes. The excess was scraped off. The filler appeared on the upper side of the planks as a brown dot with no staining. Perhaps I can interpret this as a wooden plug inserted in the deck to cover the recessed head of a bolt, nail or screw. I am not prepared to hammer in hundreds of tooth picks.
Looking at the attached photos I think it is time to turn the cutting mat over.
I'm building the Fram too. I passed on the OcCre deck plank process as well. Also passed on the trenails.
A bit more Progress
In keeping with my intention of not getting bogged down with long, repetitive tasks, the photo below shows some multi-tasking: sewing bolt ropes, making a lifeboat, pre-painting some strips. Also, taking advantge of the fine weather to make spars (and dust!) on the patio - with pipe and a beer.
Deck planks.
I made a simple jig to speed up the production of these. Bundles of about 10, cut slightly over length,, are held in the jig and trilled to represent fastenings. The excess is then trimmed from the protruding ends. The undersides of the planks are smeared with wood filler as described earlier.
Hull Planking
The first layer planking is 2mm thick lime which provides a good contact area for glue between adjacent planks. With appropriate tapering and chamfering it was possible to fit entire planks from stem to stern. The only exception was a shaped drop plank on each side to fill the gap between the last bilge plank and the garboard. The seams were tight and the hull is destined to be painted so there seemed to be little point in repeating the planking process to add 0.4mm sapele strips. So I didn't. The thick planks provided ample meat to allow vigorous scraping and sanding. In the pictures below I have temporarily attached the part of the board from which the keel was cut to provide a guide for trimming.
Priming.
In my web search for a primer paint I came across something called GESSO. I gather artists use it to prime canvases. Assuming that they do not want their paint to fall off any more than I do I decided to try it. It was easy to apply and seems to have a degree of filling property that hid small gaps in some of my rogue seams.
£9.99 for 500ml in contrast to £99.50 (= £3.98 for 20ml) for the equivalent amount of official OcCre primer.
I have begun adding the top coats: red on the bilge, black at mid height and grey on the upper sides. It is not very clear from the instructions whether the red/black interface is a waterline or should sweep up at bow and stern. Some illustrations imply one; some the other. I chose waterline.
Trying to mark a horizontal line on a curved hull with paper masking tape was not successful: lots of creases. I found some rubber backed masking tape that allows some lateral bending. Much better! The upper line of the red paint IS parallel to the keel even though it appears to sag at the bow in these pictures.
Pin Rails
The pin rails are supported on bipedal brackets supplied on photo etched brass sheet < 0.4mm thick. These have a tiny spike on one leg to be pushed into the gunwale; the other rests on the deck with no obvious means of securing. These are extremely bendy. The pin rails will eventually receive the ends of rigging threads, some of these will be in tension and the whole structure seems too flimsy to fulfil its purpose.
I have tried to bodge an improvement by inserting pins into the deck near the foot of the brackets, snipping off the heads and securing them to the brackets with a dab of CN glue. A bit primitive but it seems to help.
The pin rails themselves are cut from thin plywood with the surface grain running across, rather than along the strip. At points where pre-drilled belaying pin holes are made the strips are extremely fragile. One broke in two and I effected a crude repair. Another section broke in two places so I made a replacement. The pin rails rest on the support brackets. How does one secure a fragile wooden strip (which curves up towards the bow) to the edge of a 0.4mm brass support? Ideally, slits might be cut part way through the plywood rail but they are flimsy enough already without further weakening them. Big dobs of CN gel was the best I could manage.
My enthusiasm for OcCre waned considerably at this point.
Shrouds
In keeping with my current policy of multi-tasking I have decided to fit a mast (slightly prematurely) so that I can dilute the tying of ratlines with the job of completing the deck fittings. To fit the shrouds I have used a dummy chain plate to locate the upper dead eyes. On the bench, the pairs of ends of shrouds are pulled through holes in the dummy chain plate to form loops below it. Dead eyes are placed in the loops. Lanyards are tied around the neck of the loop above each dead eye and threaded though the first hole. At this stage the lengths of the shrouds and lanyards is generous but not specific.
Prepare two of these.
In the next stage the shroud loops are passed over the top of the mast alternating with a similar rig on the other side of the ship. The lanyards are threaded through the upper and lower dead eyes. At this (slightly chaotic) stage an upper dead eye can be raised by pulling the doubled back end of a shroud or lowered by tightening the Lanyards. These actions can be repeated to align the dead eyes and adjust the shroud tension. The upper deadeyes are free to rotate in their loops to get the holes correctly orientated.
In the final stage the lanyards have been secured and all loose ends trimmed off. The dummy chain plate has been broken free.
I am low on the learning curve of this approach. With hindsight I should have attached the lanyards only to the foremost and aftermost dead eyes. After adjusting and matching the height of these, the lanyards for the intermediate shrouds could be added and threaded one by one. This would avoid some quantum of entanglement. There are two more masts to help me ascend the learning curve
DAMN!
Or S or F or B ou M!
The hull build instructions for Fram show six deadeyes on either side of the foremast. I fitted these, looped six pairs of shrouds round the cross trees and tied the ratlines.
Later in the build I discovered that the aftermost deadeye on each side is for a topmast backstay - not a shroud.
Options,
1) no backstay
2) add another deadeye each side - but I have no spare strops
3) Convert the aftermost shroud to a backstay.
I chose option 3. I snipped off the ratlines at the penultimate shroud (and inadvertently snipped the shroud at one point but I can fix that.)
I did not fancy trying to remove the released shroud from its upper deadeye so the next decision was :where to attach the backstay? I chose a point just above the deadeye whipping then glued and whipped a new length of thread. Photo 3. When set, I cut off the redundant shroud leaving a short length beneath the cross trees to keep the upper loop intact.
I made the same mistake on the mizzen but fortunately have not tied the ratlines yet. An own goal: 50 unnecessary clove hitches and a lot of faff.
These images were the right way up in the folder from which I copied them but ended up rotated when posted. I have just used the editor to put them right..
