Brig "Mercury" from Amati, scale 1:64
I am currently working with carronade machines. I will tell you more about it here.
The roller itself is 2 brass tubes. One is 1.5 mm, the inside is 1 mm in diameter. We insert one into the other, solder and grind to size (in this case the width is 2.4 mm) as a result we get a diameter of 0.5 mm for the axis.
The parts in the photo below for the roller frame were cut out for me on a laser machine. Length 5 mm, width 1.0 mm, thickness 0.2 mm. I drilled 0.4 mm holes, although initially 0.5 mm was supposed. But very little is left on the edges of it, and I made the axle thinner
As a result, we get such a product. Please note that this is still a macro shot :)
The set offers this version of wheels for a carronade machine. Something glued together from three parts. I think the difference is obvious
20250406_184503.jpg20250406_184603.jpg20250406_184628.jpg20250408_194059.jpg20250408_194105.jpg20250408_194108.jpg20250410_150831.jpg20250410_150846.jpg20250410_201732.jpg20250410_201759.jpg
The most interesting part came next. What to make the slabs for the gun from. In the original, they were cast from cast iron. At first, there was an idea to make them from black hornbeam
It should look like this. The manufacturing process is in the photo.
This is a photo for the post above. I made a scraper, made a profile from hornbeam, then cut and drilled
The idea was rejected
While I was thinking about a new idea, I started making parts for the machine. Side eyes, the trousers go through them.
Ultimately, this resulted in a new idea and here is its implementation.
Your Carronades look super. I did not know until following your build that in addition to the British Navy that the Russians used them as well as the American and French navies. Beautiful build!
Making the latrine sidewalls. Made from a set of hornbeam measuring 0.6x2 mm. Drawn the contours on a sheet of paper, glued on one side, then on the other with an overlap of half a slat for rigidity. Cut off the excess and grind it down
20250524_153907.jpg20250524_153917.jpg20250524_163347.jpg20250524_184935.jpg20250524_185008.jpg
Bowsprit and figurehead just for fitting
