These can be tricky. If you cannot find any you can also paint these on thin paper such as light weight silk span then glue the paper on the model or draw the art work if you have a CAD program then print and glue on.Are name and scroll decals available anywhere?
I’ve tried that on plastic models and found it prohibitively difficult to match the decal background to the painted surface. Even with a black background, I found there is no single shade of black.You would need to be a computer type with the correct software, but I believe that some modelers have solved the “white printing problem” by using white decal paper and printing the black background.
What software is required? I have no idea!
Roger
The software isn't the issue. Lack of white ink is.You would need to be a computer type with the correct software, but I believe that some modelers have solved the “white printing problem” by using white decal paper and printing the black background.
Roger
www.bedlamcreations.com
An interesting event occurred while I was at Portsmouth Naval Shipyard. He showed up during the midnight shift (in civilian clothes, of course) and went to board a boat at dockside. The sailor on guard duty at the gangway stopped him and asked for ID. He said: "Don't you know who I am?" The sailor replied: "I don't care if you were Admiral Rickover, you are not getting on board without the proper ID". He stormed off.I watched the Kindly Old Gentleman sit down to dine with us and hurl a bowl of his specially-procured ice cream against the bulkhead when it wasn't at his ordered temperature, (he carried a thermometer just for this purpose, I guess.)
Very inspiring to those in attendance indeed. . . I'm sure the CO thought he might lose his command.
His initial contributions were legendary, but his service lasted at least twenty years too long. Power/fame is toxic for most people, and he was no exception.
He destroyed many capable officer's careers on a whim, which I never cared for.
He served sixty-three years of active duty mainly because of his political connections. (He was passed over for admiral twice, (three times and you're out) and had to call in political favors to get selected. So much for merit-based promotions. . .
SecNav Lehman forced him to retire, (@ 83!!!) which I applauded with great vigor and enthusiasm.
The Naval Nuclear Power Program did not suffer one iota as a result of his departure.
