Discussion The Cost of Kit vs Scratch Build: A Real Divide or Just Perspective?
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
Ahoy, fellow builders!
I’ve noticed this topic pop up here and there, sometimes subtly, sometimes not so much, so I thought, why not give it a proper place of its own? There seems to be an ongoing (and often unspoken) comparison between kit and scratch builds when it comes to cost. Some folks feel priced out of kits, others view scratch as a mountain of tools and time. But is it really about money, or perception? And how much does cost actually influence how people approach the hobby?
Here are a few points to kick things off:
  • Kits can range from affordable to eye-watering, but they offer structure and support.
  • Scratch might seem cheap at first, until you factor in plans, wood, tools, mistakes, and time.
  • Do you think one is more "accessible" than the other?
  • Have rising kit prices changed your build habits?
  • And does cost affect how you participate in the forum or interact with others?
This isn’t meant to pit one style against the other, we’re all here because we love building, but I’m curious how cost shapes our decisions, our builds, and even our forum activity.
Let’s talk!
Jimsky
Okay, I'll bite:
It depends upon the quality of the kit and, to some extent, the "you get what you pay for" rule applies. After one builds a kit or three, they should be well on the way to self-reliance when it comes to "structure" and "support," and the rest can be readily obtained from a forum such as this one, if nowhere else. In this respect, the necessity of research becomes more obvious. Many rush into building headlong without learning first the skills and techniques. Once one learns how to read plans and engineer their own models from them and develops a command of how real ships are built, there aren't many valid justifications for not building original models from scratch. It's a lot like traveling. You can jump in your car and ask directions along the way, which leaves you at the mercy of those who direct you, or you can learn to read a map. (Or at least it's the way travel used to be before talking GPS screens on your dashboard! ;)) There are many "classic" books on ship modeling that serious modelers collect and rely upon as valued reference works. Building such a library, even if it's only a half dozen of the best basic books on technique, should begin before one begins unpacking a kit without being able to identify all the parts by sight. Studying such books will also give those without prior knowledge a good start at acquiring a working vocabulary of nautical terminology, which is nearly essential whether one is building a kit or building from scratch.
There's no limit to how much anybody can spend on a hobby if they have the means, but, at the other end of the spectrum, scratch building requires very little, even in the way of tools, over and above what is required to build a kit.
Plans are often readily available at no cost at all, save perhaps the purchase of a book full of them. At most, if one is really serious about building a very accurate period model, they may have to drop two or three hundred dollars for copies of original drawings from one of the top maritime museums, but one could easily fill a lifetime of modeling U.S. naval fighting vessels from one or another of Howard I. Chapelle's books which are usually very inexpensive when purchased used online. This assumes one knows how to read the plans and tables of offsets and can draft their own scale loftings, not a difficult task at all for a kid who took mechanical drawing in high school or an adult who reads how it's done in any number of modeling or full-scale boatbuilding books. Even if one finds drafting daunting, they can always purchase a practicum. Even the most expensive ones for the most detailed period models will cost less than a quarter of what the kit for the same or similar model would run you. (E.g., David Anscherl's four volume set, The Fully Framed Model - The Swan Class Sloops, which is a step-by-step instruction manual that covers every possible step in the construction process can be had for $235 USD used on eBay. See: https://www.ebay.com/itm/1771196386...term=2324505021064440&utm_content=PMax Assets) Here again, the more you know, the less you have to pay somebody else to provide for you.
Wood is where you find it and it's everywhere. There is no reason why a scratch builder need be constrained to the "Holy Trinity" of pearwood, boxwood, and ebony at today's prices. Even if wood is purchased, very little is required, relatively speaking. Here again, knowledge is money. There are many species that are eminently suitable for modeling. Many of these are right in anyone's neighborhood. What the tree services toss in their woodchippers would make a knowledgeable modeler cry. Many ornamental plantings yield great modeling wood in quantities insufficient for commercial harvesting, but plenty for modelers who only need small pieces. It depends where you live. Here in the U.S. cherry, apple, and pear trees grow most places, but only cherry is readily available commercially. Recycled wood should not be overlooked, either. Ebony and ivory are free for the taking in small pieces from discarded old pianos. Some of the high-grade real mahoganies and walnuts are to be found in old discarded furniture, sometimes hidden beneath a few coats of house paint. Keep an eye out for solid mahogany, chestnut, and walnut doors and trim from old building demolition, too! (I'm not talking about the low-grade open grained highly figured stock found in the model kits here. I'm talking about the really good and now unobtainable stuff that is suitable for scale modeling.)
Tools, as mentioned above, are no different than for assembling kits. There's no absolute necessity to invest in expensive power tools to scratch build. The expensive tools only make the job easier and faster. Actually, for many, acquiring and owning the tools many invest in is part of the joy of modeling, scratch or otherwise. However, it is important to note that just as "knowledge is money," so also are tools money for the scratch builder. This is particularly so with respect to a decent scroll and micro-sized table saw and a thickness sander. Getting out curved shapes with a hand saw can be very tedious and a suitable used scroll saw can be had for fifty bucks. The table saw is necessary to get out strip wood and saw larger pieces to size and the thickness sander needed to size stock. These operations can be done with a hand saw and a plane, but, here again, it's tedious work and considerable skill is required to do it well with hand tools. More significantly, if one is doing their own milling, the micro saw blade takes a tiny bite, while a larger saw (Harlod Hahn used an 8" table saw when wood was cheap) eats up a lot of wood in its kerf. The thin slitting blades avoid turning half your planking stock into sawdust to yield what you need. I'll mention at this point that in my opinion, and those of many others, the Byrnes Model Machines table saw is the only one worth spending money on. I think they are around $500 US these days, but you can always sell it, possibly for a profit, when you're done with it. Milling larger billets down to scale size milling stock can always be done if you have a friend with a bandsaw or large table saw, or access to a local high school or junior college wood shop classroom. There is no question that if one mills their own scale wood, they will not only free themselves from the limitations and expense of dimensioned scale lumber but also will certainly amortize the cost of such power tools with the savings over buying milled scale stock for three or four models and as mentioned, such precision tools maintain their value well over time. Buying used tools in good shape also promises large reductions in acquisition costs, obviously.
Mistakes cost the scratch builder nothing. It's just a "do-over." There's no need to buy replacement parts or abandon a kit when the lost part is no longer obtainable. How much money has been wasted by kit buyers who become discouraged and frustrated with expensive kits and never finish them, or worse, collect expensive kits they will never have the time to build? Most scratch builders have far larger "stashes" of unbuilt kits in their heads and on the shelves of their libraries than any kit buyer could ever imagine! Redface
Time is also a non-issue for the scratch builder. What the scratch builder might spend in time is saved in money. The scratch builder's knowledge takes time to acquire, but, aside from research and planning being a joy in itself, the scratch builder doesn't have to pay the kit manufacturer hundreds of dollars to have done it for him. As for the satisfaction many find in creating a unique one-off model of a vessel rarely seen elsewhere, the ability to say, "No, it wasn't a kit. Everything you see there is my own work." isn't available at any price anywhere else.
That depends upon what you mean by "accessible." Kits are readily "accessible" and so are scratch build subjects, but, as noted above, kits permit one to purchase what the scratch builder acquired by study and experience, and yet, the scratch-built model is a unique artistic expression of the builder's research and creativity. If that makes any difference to a modeler, the scratch model may be less "accessible" to the less experienced modeler (or as I call them, ship modeling's "gateway drug.") Kits certainly have their place and most scratch builders started building kits and "grew out of them" as their skills and experience increased from their experience with kits. As for economic "accessibility," it's my guess that somebody could get started in scratch building with an initial investment of a few hundred bucks in tools and books which would then serve to build as many models as they might desire with very little additional cost (until they started wanting fancier power tools,) while a quality kit could cost the beginning modeler as much, but likely two or three times as much, just to buy their first model and each and every one they built thereafter would require the same expense again.
No, but only because I lost interest in building kits long ago. If I had limited myself to building kits, I doubt I'd be dropping the money they want for the good ones these days. I don't begrudge the kit manufacturers' their "rice bowls," but I am afraid that economies of scale production and the production costs today very likely are on the road to pricing kit building out of existence. I expect that the future of "accessible" ship modeling is now in the quality practicums of authors like David Anscherl, Jean Boudriot, and Harold Hahn, rather than the four-figure "mega-kits."
Not at all. I am, however, keenly aware that those who are new to ship modeling may not have the money to bankroll the sort of workshop and tool collection I and other "old timers" have acquired over decades of modeling. I try to encourage them to take it easy and budget for the "must have" tools, buying second-hand as I have over the years, and "making do" until something affordable comes along. "He who dies with the most tools wins!," but nobody has to buy them all at full price right out of the gate!
So now, I've risked getting "flamed" for being "elitist," or worse, earned the enmity of the kit manufacturers, but that's how I see if from the perspective of more than fifty years in the game. I'm not rich, nor "elitist." Neither am I a "world class" ship modeler. It's just what I do for fun. (And, sometimes for money, but then, I've discovered, it's not as much fun.)
I'll bite:
Hi Bob,
You’ve raised a lot of thoughtful points. I don't think I'll be able to respond to each of your comments, but I appreciate the passion and depth of your experience. However, if I may offer a different perspective, from someone who builds kits and firmly on the “kit builder” side of the table:
My most recent completed project: the Leudo Veneziano kit by Falconet. It cost me about $160.00 made in Pearwood and includes everything: quality parts, fittings, pre-sewn sail, step-by-step instructions - all designed for authenticity and without needing aftermarket upgrades. It's honestly a great value! This model was built as is, from the box... using a hobby knife, rotary tool, and wood glue (not supplied).
Now, if I wanted to scratch-build the same boat, the ANCRE monograph alone is around $130.00. That’s nearly the full price of the kit, just for the plans. Then there’s the question of acquiring the Perwood, milling billets into strips… but I don’t own a miniature table saw. Should I buy one or buy pre-milled strips? Let's say the tablesaw will cost me $350.00. Do I have experience operating it? Alright then, I should buy the milled billets and strips. Shall I add another $200.00 for the cost of milled wood? Should I continue with my math?
So while scratch-building has its own charm and rewards, comparing it to kit building is a bit like comparing apples to oranges; for the most part, kits offer a different, more accessible and affordable path that’s no less satisfying for many of us in the hobby.
happy modeling,
this said it all if you in it for the long run scratch building is far,far less expensive than building kits. I can build a 1/4 scale model of the Mississippi 1840 plank on frame hull that would be almost 6 feet long at a 1/3 the cost of one hi end kit. How ? because first i know how it was built and know how to do it. Materials i can pick up quality Cherry for a cost well under 100 bucks.
i am in the wood business for 40 some years and so many times i get someone saying " i was on this model ship forum and they said you HAVE to use Boxwood or Swiss Pearwood if you want to build a ship model.' so i quote their request and get a WOW! sticker shock i can't afford that. Well that is a bunch of bull you do not need those woods you can go to Home Depot and buy some Hard Maple or go to a local wood store like Woofcradt and pick up some Cherry or Beech there are so many other woods to use.
i am with Bob on this one. I built 2 kits over the last 40 years and quickly kicked kits to the curb thinking i can do much better starting from scratch and never looked back. Personally, i would not pay the price for a kit these days.
Bob says not at all i say yes it does affect how i participate on the forum. if i wanted to gain thumbs up and points i would buy kits and do build logs on how to assemble them. but that is not what i do i introduce scratch building projects to maybe expand the experience of model ship building and perhaps suggest you do not have to take out a second mortgage to build that dream model.
Dave, your post gave me a good chuckle. No one needs to take out a mortgage to buy a kit! But seriously, why is it that whenever kit building comes up, people immediately think only of the ultra-expensive "mega kits"? There are plenty of well-designed, affordable kits out there that can produce beautiful, maybe not so historically accurate models, often for less than the cost of a single tool needed for serious scratch-building.
Hear me! Not everyone has the time, tools, or desire to mill their own wood, read the drafts/plans, and that's perfectly okay. Kits offer a structured, accessible path into the hobby that many find deeply rewarding. It's not about just collecting “likes” or praise - it’s about the joy of building something with your hands, learning new skills, and connecting with a like-minded community.
that is a Toung in cheek comment a little sarcasm and not to be taken literal
because of the movies, museum models and the desire to have that big 100 gun ship with the cool figurehead and all those carvings. They look good and that is the attraction so yes it is the mega expensive kits that draws attention.
That's a fair point, 100-gun ships with ornate figureheads definitely have a strong visual appeal, and movies have certainly popularized them. But I don’t think it’s accurate to say that it’s only the three-deckers, ships of the line kits that draw attention. Expensive kits are mostly POF kits, a new line of kits adapted for use with CNC machines. Because of the POF, they are usually made with Pear or Box wood, which adds to the cost.
There are plenty of well-designed, modestly priced kits that capture people’s interest just as much, sometimes even more, because they’re approachable, buildable, and historically meaningful.
You don’t need a 3-foot man-of-war to enjoy the craft, learn skills, or build something truly satisfying, but ... if someone wants to build it, go for it and enjoy!
Years ago there was an oil change commercial (I think Pennzoil) where the mechanic said “you can pay me or pay me later.”
Scratch building is seen as an example of “Pay me now” due to its perceived high upfront costs. Not necessarily so! For me buying tools is a way of life. My full sized power tools; table saw, jointer, bandsaw, drill press have paid for themselves many times over as have hand tools on tasks not related to model shipbuilding. The expensive power tools were bought over time as money became available. Used tools can be excellent buys and fun to hunt down. It CAN BE a choice of where to spend your money. My now adult kids have never been to any of the major theme parks. Despite this they are happy well adjusted and productive.
One the other hand, living accommodations can be a deterrent. The dirt, noise and space required are incompatible with apartment dwelling. My career has permitted me to always live where I can enjoy a dedicated shop.
I agree completely with Bob and Dave’s observations above.
Is the cost of model kits a deterrent for me? NO! Because:
I want to feel that I built the model.
I want to model subjects not offered by kits.
I want to control accuracy and quality.
I enjoy doing myself services offered by the kit designer/ manufacturer.
Would I build a kit if it were offered to me free? No, I don’t have the time.
My thoughts that apply only to me.
Roger
Just a small comment, part of the high cost of POF and even some of the large kit come from the ease of having details. You need serious equipment to get all those lasers cut parts (some quite tiny) and most numerous. It can be done by hand, but you need very good equipment, skills and a lot of time ahead of you. Second, etched parts: provide a lot of details BUT not obvious to replicate at home. Third, CNC parts: again, can provide a lot of details without being skilled at carving. Again, another layer of cost and skills. Lastly, plans and drawings: using freely available plan are not enough in my mind. You need quite some skill to get those into a practical building plan (even CAD skills could be needed for complex build). Overall, scratch building could become VERY expensive. For me, it is not worth the entry cost. I rather jump right away in a build and think of possible improvement along the way.
I was VERY interest in scratch building for the obvious flexibility of choosing the ship. BUT the above just turn me away from it. I may be wrong though; I never scratch build. The major drawback to kits for me is not cost but availability... 125% tariffs on Chinese POF, or complex plastic battleship kits to the US, come on!!
I really think there are pros and cons to each, based on my own experience. Each person needs to know their needs before making a choice. Addressing just the five from Jim.........
Plans - There are thousands available for free, including at least 800 high resolution images of English ships and boats. The design plans are generally accurate and detailed. Even more accurate are plans of ships captured and then drawn up by the English or as-built plans. Reproductions for a kit should be equally accurate, but that is not always the case. On the fun side, most kits are based on original plans so can be compared for accuracy. Or if it is a ship for which there is no detailed contemporary information and is more or less anyone's guess for ships like the Santa Maria, or fictional pirate ships, etc. it is still fun and why not go with a kit?
Wood - Many kits still seem to use sapele and other cheap poor quality woods. Others now offer tight grained high quality woods so it comes down to part of the price issue as well as a consideration of how it looks compared to the cheap species. Scratch building does open us up to choosing the species we want be it box, castello, pear, holly or any other high quality species.
Tools - I have no laser or CNC equipment nor the ability to program them but I am somewhere in between when it comes to modern tools. I use a scroll saw instead of a laser as it is faster and easier for me. Drills and other hand tools are great to have even for kits so no added investment is needed for either kit or scratch. BUT, stocking a shop with all the other tools for scratching can be prohibitive if bought all at the same time. Adding a tool like a table saw, lathe, thickness sander, etc. one at a time over several years is not too bad. I would not go the scratch route if I was considering it for the first time at my age today due to the initial investment and now that we finally have one or two kit makers that produce a high quality product I would go in the kit direction.
Time - The value seems to go up as we get older so it comes to priorities in how we use it. If I use a large percentage on ship modeling, be it research, scratch or kit, it is worth it to me no matter how much time is involved. For me it is as much about the journey and the sights along the route I take as much as reaching the destination of the finished piece.
Mistakes. If a kit mistake like bowling pins for belaying pins, completely wrong planking, and the list goes on, it is hard to justify spending time and money fixing their mistakes. Scratch building has an advantage there, except for those skilled at kit bashing. Again, with a couple newer kit makers out there that produce a very high quality product, maybe the bar has been raised for the rest of the old time producers to finally up their game.
Hi Jim,
You do have a penchant for creating topics that generate posts that drive me crazy ROTF ROTF ROTF.
Paul
I would respectfully challenge some of the dogma...
"Kits are expensive." Perhaps. But given the fact that it takes me 2-3 years to complete a mid/full sized ship model the cost spread over the lifetime of the build is quite small. A single round of golf at a local course far exceeds my per-month kit cost (even with upgrades).
"Just acquire tools over the course of your lifetime and that makes ship-modelling less expensive." I like this on the surface. But what if someone doesn't have decades left to spread out the cost of tool/machine acquisition? Or what if they don't want to wait a decade to start building their first ship model? And make no mistake, quality tools and machines are expensive.
"You can build a ship model with an XActo, a coping saw, and your dad's rusty old files." I sort of made this one up but it has been implied. Yes, I could. But do I want to? Is that the best use of my limited hobby time?
"Just get less expensive wood for your scratch build." Again, I sort of like this one. But there's a reason scale modelers like to use the expensive hardwoods: they make a very nice presentation. This one ends up being more a question of what you will be satisfied with. In my case I'd rather spring for the better material so that my 2-3 year investment presents well. Fuzzy edges and grainy surfaces can be avoided by spending 50% more on preferred species; plus, it's not like cherry and maple are free from the big box store.
"Free plans..." I'll say this one is misleading. I do not have the skill or desire (or hobby time) to loft frames from a few downloaded drawings from the NMM - never mind the balance of the wood components of a ship. That means I need monographs. Monographs are expensive. Just making accurate copies of scale drawings is expensive.
I guess where I land on Jim's topic is that there is much ado about COST as if it were possible to hold that out as the single most important compelling argument for why people get into ship modeling (or don't) - or should use a particular approach to modeling versus another. I think that position is a nonstarter. You can find inexpensive ways to build from kits - and you can find inexpensive ways to build from scratch. You can also find expensive ways to build from kits - and you can find expensive ways to build from scratch.
Wouldn't it be better to just support people in whatever approach they might choose? Read the room! If someone is wanting to build directly from the kit help them do that to the best of their ability. If someone wants to build from scratch help them do that to the best of their ability. If someone is clearly on a budget - give them tips for improving their outcomes on a budget. If someone is clearly comfortable with investing more in the hobby - guide them toward resources that maximize their outcomes in that particular lane.
And if someone is just trying to have fun then celebrate their accomplishments without pushing them in a direction they aren't wanting/trying to go.
Thanks for reading.
Hi Bob,
happy modeling,
The thing that I find annoying with kits, and I have done a few, is that there seems to be always something missing; be it wood or otherwise. I know customer service is important but I would rather have the darned piece and not have to contact customer service.
Fair point, Jack! It is frustrating when something’s missing from a kit. But I think it’s worth remembering there’s no right or wrong way to enjoy this hobby. Some love the flexibility of scratch-building, while others genuinely enjoy the structure and convenience that kits provide. And with so many kit manufacturers out there, the quality and completeness can really vary; there are definitely some doing a great job. At the end of the day, we all find satisfaction in different ways, and that’s what keeps this hobby rich and diverse.
I wish I could do a scratch build, but the cost and availability of materials are problems where I live so I have to resort to kits, which is ok because I have enough inventory of wood and spare parts to customize the kits a little. My next customization on the Constitution will be the rigging thread which I want to make from scratch. But anyways I love the hobby, and it keeps my mind occupied. I also have started adding some pieces via a 3d printer, instead of the britania metal fittings which I find are not of the best quality. But that`s just me.
I assume that building one model is very boring, so i usually start one set at hull base, one set on the rigging and one project from scrap. Three models in total, always at a similar stage of work. When i get bored with the hull, i go to the rigging, when i get bored with the rigging i go to the monographs... and so on round trip. The biggest problem is tools, but who said they have to be new?. I bought some of the equipment as damaged, no wirking but wxtremly cheap, sometimes it was enough to replace the switch for example. Some of the equipment is used, it is a 50/50 risk of buying, but it is worth trying. It can be organized, but it is a long-term purchase project, it is not possible to have everything at once, unless you get a lot of $$$.
For me everything is possible, just it is a slowly move and lern from sandpaper to disc sander.
From a NOVICE builder, I will give my input to the questions as I see them, having similar issues in other hobbies.
    • This is one factor, but if you want to just build a simple ship, not worrying about accuracy then kit models are best for money, but if you want a accurate kit with quality details and accessories, as the old saying goes, "you pay for what your get"
    • They may cheap in cost of ship, but as said, cost of tools, and equipment needed to do pure scratch building adds up quickly, then there is cost of personal time to research, review, draw out details and such, much of which is provided in kits now a days.
    • Today with the internet accessibility is not as much an issue as many years ago in past that the "great modelers" had to deal with, and we can travel to museums to visit many ships now that couldn't be done in past.
    • Yes, I am a bit more selective, and buying new high quality kits when announced as they may not be available in years or even months down the road, as many are limited production now a days.
    • NO, this is best place to learn and it only costs my time online, and it allows me to intact with many folks whom I would never have meet, anywhere else if I had to go face to face or track and search for local clubs to help out.
This is a great topic with a lot of different view points which I have really enjoyed reading from a lot of members. These comments make me feel a lot closer to other members in understanding their particular out look on the hobby. As for myself I must reflect back about fifty five years ago I purchased my first wooden ship kit, Billings Danmark. Along with a few other wooden kits of different types of vessels I soon discovered where I belonged in this hobby. That was in studying ship blueprints, doing research, and realizing I don't need to spend the money kit manufacturers were asking for their products. Being very determined to scratch build models myself I searched through the many plan sources which were available in those years as scratch building was what modellers did. To get my wood I generally found old furniture that people were throwing out as a lot of it had quality wood before glue and saw dust furniture hit the market. Yes I did have to purchase a variety of tools over the years, but over a period of ten to fifteen years the cost was not too bad. As a scratch builder my hobby tuned into a business, and due to time demands I have turned it back into a hobby.
Scratch building or Kit building;
That can only be determined by the individual modeller. I can only say in my case that I would rather spend my money on tools, plans, and wood rather than over priced kits. However, had it not been for those initial kits I don't believe I would ever started on the path of scratch building.
I build both scratch and kit. Price isn't a factor for me. I have a good selection of tools - basically everything mentioned in the above posts. I find that I also use my 'high-end' tools a great deal on kits / for kit bashing. Of course it seems like I use them more when building from scratch. In many cases I now like building from scratch more, but I continue to purchase new kits that catch my eye - some are so much better than what I started with. Kit structure and support is very much a function of the kit - even from the same company, again some of the newer kits are fantastic from this perspective. The cost has no affect on how I look at forum members work. There have been some cases where I've seen individuals getting really nice results from $20 Harvey kits they purchased on Amazon - that amazes me. At this point of my modeling development, I feel that generally I can get a better result with more ease scratch building than I can trying to make a kit work. In many ways, kits are a bigger challenge - trying to make the given piece or material work vs doing it 'right' with a handmade replacement.
One of the biggest things I don't like about kits is laser char, something I don't need to deal with when milling and cutting without a laser.
I have a kit stash that has probably 3 dozen ship models; periodically my wife asks me why I don't sell some. Last time she asked, I told her that there will come a time when I won't be able to use my table saws, band saw, lathe, mill ... due to health and/or living arrangements. I still hope to be building boats, and kits will likely be my main opportunity with a reduced toolbox of (mostly) hand tools.
Falconet's Leudo Venexiano appears to produce an excellent model and many have sung Falconet's praises, but the kit you've cited as an example is somewhat "the exception that proves the rule."
There's no mistaking that $160 for this model in pearwood is a real bargain in my book. There are many bargains to be had on ship model kits and if eBay and the various forums' "for sale" sections are any indication, "Only a fool would pay retail." Obviously, anybody who is interested in building a ship model is certainly no fool, so if one is so inclined, the amazingly high MSRPs of many models should be taken with a grain of salt and "shopping around" is in order.
Unfortunately, Falconet is a Russian company, and the present state of international affairs seriously limits the availability of their products and parts replacement availability in North America. While there appear to be some Falconet products "in the stream of commerce," presumably having been imported by U.S. and Canadian retailers prior to the present trade restrictions, it would appear that for those of us on the other side of the political divide, I'd consider Falconet "out of business" for the duration, for our purposes at least. (And North American retailers may be selling Falconet's kits at "clearance" prices to get rid of them before they become more difficult to market here.) Notably also, with overseas suppliers which are still doing business internationally, sourcing missing or broken kit parts will often involve exorbitant (IMHO) shipping costs and waits of weeks to for orders to arrive.
Falconet's product line contains a good representation of smaller vessels which are excellent subjects for modeling and that keeps the cost of those kits "accessible," in theory at least, given they will become increasingly difficult for non-Eastern Block modelers to source. Parenthetically, these type of craft (which I expect Howard I. Chapelle would deem "models which should be built,") are particularly suited to scratch building because they don't require a lot of fine metalwork and carving. On the other hand, Falconet offers other kits that are surprisingly expensive, such as a simple two-masted schooner with a list price of $1,250 at present exchange rates, to which, presumably, will be added significant shipping charges and, likely high tariff taxes, which will bring us back to the reality of initial kit expense. To greater or lesser degrees, depending upon the day of the week, or so it seems, the present instability of American tariff taxes must be expected to substantially increase the cost of any imported ship model kit and particularly those produced in China.
From what I understand, Falconet does not provide translations for their Russian language instructions, so that may be a consideration for those who must parse the meanings of various illustrations in their instructions in order to build the kit. To that extent, the novice builder will find himself doing "research" no differently in those respects than the scratch modeler! (And be a better modeler for it if they survive the frustration.) Also, Falconet's product line focuses on subjects of which their primary customer base would be expected to have an interest and, conversely, in which a North American customer base would be less interested. This perhaps touches on the issue of "availability" in a different way than previously discussed: the kit modeler's choices of subject matter are limited to what the applicable market demands, too often "over and over again," or, as Howard I. Chapelle called them, "models that should not be built." Unlike indisputable authorities such as Chapelle and Hahn, my opinion has no such weight, but, IMHO, I find your Leudo Venexiano far more interesting than another Victory or Constitution. The former offers new information that adds to my store of knowledge about watercraft, while the latter primarily only offer an expression of the kit builder's technical ability.
I do have to stress that there is nothing wrong at all with building kits. If that "floats your boat" and isn't broke, don't fix it. Just keep kit building and be happy. There are very few scratch builders who did not begin their ship modeling "careers" by building a kit. After finishing a kit or three, they moved on for any number of reasons. Some decided the cost of a kit was more than they needed to pay to build their next model. Some wanted to create a unique model, while others found that they had no choice but to scratch build their next model because nobody offered a kit of it. And, indeed, some found buying their next kit an attractive option. Six of one and half dozen of the other, as they say.
Now, in the spirit of full disclosure, I must say that there is an important difference between scratch building and kit building which in my experience following ship modeling forums online for as long as there's been an internet is very apparent but rarely fully discussed without walking on eggs for fear of raising hackles. A good ship model kit should enable a person who has a minimal familiarity with basic tools but knows little or nothing about vessels or their construction and operation, to build a credible model of one. The scratch build requires that the builder be fully familiar with the construction and operation of the prototype vessel they are building, together with all the knowledge of how to engineer a credible model of their subject. Scratch building requires a working knowledge of a lot of basic skills, including, but not limited to, academic researching, all the manual arts which are involved in the build (woodworking, metalworking, finishing, rigging mechanics, etc., etc.,) working vocabularies of drafting and lofting (a "language" in itself,) and nautical nomenclature (which is extensive and infinitely more so in the case of periods centuries ago,) and a library of reference books (and online access) which provide the information necessary to complete all the tasks required. Scratch building demands a "lifestyle commitment" to the subject which, in its more developed stages, requires the cumulative acquisition of knowledge driven by a consuming interest spanning decades. On the other hand, a good ship model kit, for a price, (hopefully) provides the knowledge to build that one kit alone. (This is why, in the days before kits were made, the stereotypical ship model builder was a mariner who'd "swallowed the anchor" and modeled ships in their retirement.)
There need be no qualitative comparisons between the two alternative approaches, nor, certainly, between their respective adherents. Their models should speak for themselves and in doing so, their most important audience is always their own builders.
In conclusion, I will offer a caution to kit builders which, if kept in mind, may save them grief in times to come. From a economic standpoint, despite, if not on account of, new technologies such as 3D printing and CNC laser cutting, and the price of materials and the marked increase in international freight costs, ship model kits appear to be a product which is even now only holding on by a thread. I am afraid making them is becoming a business model that just doesn't "pencil out." Just as we've seen the classic "neighborhood hobby shop" become critically endangered, if not yet extinct, so also has their reason for existence constricted, online retailing notwithstanding. We've become more of a society of "spectators" than of "players." Streaming television has driven the last nail in our society's post-war concept of "hobbies." A significant portion of the ship model kit market were once "point of sale" impulse purchases. The finished models in the hobby shop windows sold a lot of ship model kits bought on a whim and never built. I don't know the specifics of the industry, but as radically reduced online "sale prices" become increasingly common and we find ourselves musing about how to generate interest in our hobby, the unmistakable smell of death is in the air. It is difficult to know whether kits are intentionally overpriced with the expectation of dumping inventory just before inventory tax time, or the retailers are simply cutting their losses and unloading product that isn't moving, but we must assume they are astute businessmen and price trends indicate the marketability of their products isn't what it used to be. The relatively new marketing phenomena of "limited edition" kits and "kit upgrade bundles" further suggests manufacturers are pressed to raise prices and move product.
What I suspect may come to replace ship model kits entirely will be the marketing of plans and building practicums, possibly together with optional raw building stock and fittings sold separately online by a limited number of vendors. This really is how ship modeling worked in the days before kits existed. Everybody will, to some extent, have to become a scratch modeler if they want to build a ship model. Because the market niche is so small, there may be just enough meat on the bone to make a reasonable profit publishing practicums, modeling plans, and instructional materials. Even though, writing them will always probably be a "labor of love." Those who "build only kits" will have to adapt. Darwin was right: "Organisms which fail to adapt to changing environments go extinct."
... no comments.
