A bit larger and more expensive than I was looking for.
I agree, most likely would lose a finger or two with that one.Well that has one feature my high end strip cutter doesn't have! I need a finger protector, as I nick myself on the end of blade from time to time on my chopper.
Are you saying that a 1/16 strip could not be cut with this?I have one of those gillotine paper cutters in my shop. It’s great for cutting brass sheet up to about .015” thick. I use it all the time. It’s designed to cut with one side, a flat sheet laying on the table. When the object that your cutting gets narrower than about 2” it doesn’t work very well.
Roger
That's very similar to one sold on Aliexpress for about £40 - But check size, I have one that is a lot smaller than it looks in the ad. & only suitable for 1.5 mm thick stripwood.Hi Jeff,
I think this is the sort of thing you are looking for, this one is on the pricy side but looks well made.
RP Toolz Mitre Cutter for Plastic, Styrene, Wood & Soft Material Cutting | eBay Australia
2pcs 45 degree fences 0.3 mm blade for general use 0.25 mm blade for the fine cuts adjustable stop Material: Anodized aluminium, cutting mat.www.ebay.com.au
Cheers,
Stephen.
Thank you for the link, I will check it out.Hi Jeff,
Cheers,
Stephen.
