I have the same and I am very satisfied, seems to be solid ( aluminium, they say )Its a bit expensive to buy but uses cheap single edge razor blades and is vey solid and quick should last a lifetime
nwsl.com
nwsl.com
I have the original chopper that I bought perhaps 30 or more years ago. It has a longer base board than current models and has hold downs secured by screws. In addition, it has stops so you can repeatedly chop pieces of a specified length. If these features are useful to you, one may show up on Ebay or a comparable site. Im would post a picture but I'm in Brooklyn and will not be back to Marbletown until late in June, where the device resides.i have both the chopper & chopper 3. https://nwsl.com/collections/the-chopper-iii/products/the-chopper-iii
You can get them on eBay search for heavy duty razor bladeI have the same and I am very satisfied, seems to be solid ( aluminium, they say )
but what do you mean by " but uses cheap single edge razor blade" ? you can replace yourself ? How do you find these blades ?
They can be found on Amazon. Your local hardware store should also have these.I have the same and I am very satisfied, seems to be solid ( aluminium, they say )
