This little jewel will be worth all the time and effort you have invested; it's just amazing Johan!
Wow! That's quite wonderful modeling!
In real in scale 1:1 it’s a complex part rods and pivot points. In your scale even more, Johan. And it’s functional! Just a. Big WOW. And a clever solution for the switch.
Thank y'all for your supportive remarks, it's part of being able to continue.This little jewel will be worth all the time and effort you have invested; it's just amazing Johan!
Well done, Johan! It took some time but the light are on and the wires …….. uuh …. no wires visible.After gathering my courage, again, I decided to connect the lights through the switch to the power supply. It was quite a tedious affair; I had to and solder and temporary attach the center tanks and stow the surplus wires in the RH center tank. After a few hours I could test the lights and lo and behold, light! This also means the center tanks are permanently attached.
Below a few pictures with the center tanks installed and with lights off and on
Tanks installed:
Lights on:
And a view from below looking up:
It’s all in the details, different on the left and right! Very nice, Johan.Registrations added to the two outer tanks and temporarily installed those to check appearances. So far, so good:
Not sure yet whether or not I’ll weather her once completed. In the earlier stages of the build I was experimenting a bit with some primers and one of those shone through quite aggressively and was subsequently abandoned.Brilliant. Are you going to weather it once you’re done? Or keep it factory new? Reason I’m asking, is that in earlier images it looks like the red has some (perfect) browning to it. Just a thought.
And of course you caught it…It’s all in the details, different on the left and right! Very nice, Johan.
Regards, Peter.
A technically advanced result, Johan. With a beautiful color combination.Despite the "heat wave" currently over our country (32C/90F) I booked some more progress. All four tanks are now permanently installed, as well as the instrument panel and the 6V battery. Also the system for the tail rotor pitch control is complete up till the rotor mast. Also applied two semi gloss clear coats on the tanks, center box, instrument panel and battery.
Attention has shifted towards the two seats. The first items of interest are the backrest. These are fabricated from dia 1mm frame and 0,3mm brass sheet. Tonight I soldered the frame to the backrest. The backrest still needs some TLC, but I am not entirely disappointed with the current outcome.
View looking fwd, lights on. The 1:48 monstrosity just in front of the 1:24 model.
Detail view, looking forward, with a nice view on the instrument panel, with the battery just in front of the instrument panel and a close-up view of the tail rotor pitch control system.
Before being able to complete the pivot installation I had to modify the upper pivot fitting the provide clearance to the pin in the upper lever.
View looking up/aft. Distinguishable are the nav light installations to the bottom of the floor and the two control rods, coming from the pedals. Unfortunately, the torsion shafts are not so apparent, but, they're still there.
This last picture shows the backrest, still rather crude, dimensions 27mm by 22mm. Up next is the seat itself. Unfortunately details of the seat are very sparse, so this will require quite some AL-FI.
Hidden treasure!I found this on Reddit:
Flight trials in Norfolk, 1959 both for crop spraying and hunting platform. No more details available.
Pretty impressive, my friend!
Excellent welding on the seat back and the colors pop out at you. Your instrument panel is among the best I have seen in terms of crisp realism.
Yeh, I basically can't neglect the temptation to add details. Especially the scale, 1:24, makes it possible to add some nice details. My earlier attempt on 1:48 was too small to add details.You are going into a lot of detail! Excellent. And the soldering ... I'm sure I'll need some lessons before I get to solder such parts.
